Hi!
In the Bios check if IDE prefetch... is enable for fast block transfer, HD type on Auto etc...
Also, what OS are you using? If windows, did you installed the right drivers? (Silly question, I know, but... ;-) ) If using Linux 2.6.x try a 2.4: There's a faulty module, via82cxx that may yield to bad transfer. A patch is on his way as far as I remember.
Then, check IDE cable, no CD/DVD on the 80 IDE cable, swap memory to check if it is O.K. ok, you know all of this. I stop! :-D
Quote: Originally Posted by JC-S60
Check for bottlenecks in the system.
Check CPU, check if you can do 2 transfers at the same time over the 2 nic's (on board and other), run some diags. Maybe try another OS, just to check.
The pci should do more, as the hdd controller runs off it too...
