Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-05-2004, 04:41 PM   #1
dacndar is on a distinguished road
Using an XM direct as an XMPCR
Hello everyone,
Here is what I see as the difficulty in using the XM direct to replace the XMPCR.
I got one over the weekend along with a smart adapter for Sony head units. I wanted to see if the XM direct could be used with software applications already written for the XMPCR. Last year, I built a stand-alone controller for my PCR with LCD display and IR remote control capability. It was getting close to completion but when the Roady 2 came out I figured why am I going through all this trouble to build it myself and I abandoned the project. So I know how to successfully talk to the XM tuner module that is in the PCR and I believe also in the XM direct.
The first problem is that even though the XMdirect uses the same "can" tuner module as the PCR and most other XM products, the data input from the smart adapter connected between your head unit and the XM direct, translates the protocol from whatever brand head unit you have to the protocol that the XM direct understands. In other words, the data input comming in on the mini 8 pin connector on the XM direct unit goes through an RS232 to TTL level converter (max3221) then to a microprocessor (an ATMEL mega8) in the XM direct unit and then to the XM "can" tuner module . A proprietary protocol is used between the head unit, the smart adapter and the XM direct unit. The smart adapter also has a microprocessor in it (ATMEL Mega32) which translates communications from the head unit to a protocol which the XM direct understands. In contrast, in the XMPCR, the data from your pc goes through a USB to serial converter chip (FTDI) in the XMPCR and then directly to TX and RX of the the "can" tuner module. So while it is not impossible to use the XMdirect as a PCR, it will require some modifications to bypass the CPU in the XM direct and talk directly to the tuner module. There is an RS232 to TTL converter chip in the XM direct (MAX3221). Which can be used to talk with the serial port of a PC but the ATMEL CPU must be bypassed or disabled. The ATmel CPU can be tri-stated by holding reset low. This would eliminate having to cut traces to isolate it from the tuner module. This would allow you to communicate with the XMdirect using a serial port and the existing software out there but if you want USB connection then another driver chip will be required. I'm wondering if it really is worth the trouble.
dacndar is offline   Reply With Quote
Old 10-05-2004, 04:52 PM   #2
ktritz is on a distinguished road
I sure hope it's worth the trouble to someone as that's what I plan on trying as soon as it's figured out.
I've debated running down to Circuit City to pick up a Direct unit, but I don't have much time to try and get it to work.
ktritz is offline   Reply With Quote
Old 10-05-2004, 05:03 PM   #3
Well I am going to do whatever it takes to get it to work. Since I already have a PCR I'm not in as much of a hurry. I was hoping the XMdirect would have been an easy solution. Have you seen this thread? http://www.mp3car.com/vbulletin/showthread.php?t=33165
Old 10-05-2004, 05:54 PM   #4
Registered User
gork's Avatar
gork
I have been looking into this project as well. I believe I hae a simple fix to make the XM Direct speak the regular XM protocol, but I will have to actually get my cable built and start testing to be sure. I'm making no guarantees, but if it works, it'd only cost about $3 in parts, though it would void your XM Direct warranty! I am working on buying a house this week, so I am a bit pressed for time, but maybe I can bounce the ideas off of those who have the time to actually solder it up and test them... Btw, dacndar you have a PM
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 10-05-2004, 06:30 PM   #5
HybridMike's Avatar
HybridMike is on a distinguished road
why would you void your direct warranty?
you can do everything the pcr does through the headunit port.... besides any modifications to the xmDirect itself would put you in a legallity issue with xm....remember the reason that they discontinued the pcr is because they want to stop the mp3 recording with time trax...if you are modifiying there product you are allowing this to happen again and could put an individual at risk.....just a word of advice.....we have been working on this and I can assure you that the two devices are quite diff in protocol the main problem we have been having is getting it to sync up before the computer takes full control....and what i mean is when the unit has power applied to it (12v) the first time the headunit makes a communication with the tuner...there is some sort of syncing going on.....once this has happend we can remove the controller and operate solely on the cpu ie....power on/off channel ....ect....
we have sent the direct to our engineer at the college here in orlando to fully analyze the syncing process.....we should know by thursday whats going on with it.
HybridMike is offline   Reply With Quote
Old 10-05-2004, 06:36 PM   #6
I agree that your solution is more elegant and safer as far as legalities go. I hope you succeed.
Old 10-05-2004, 07:33 PM   #7
NOS TANG's Avatar
NOS TANG is on a distinguished road
Mike I respect your work and advice on this subject, but I see it a bit differently. I find toslink mods and moded PCR's selling on eBay and other sites every day. The guys over at xm411 claim that xm had no problems with them making the mods, or adding them to stuff they sell as NEW.. Once you purchase a piece of equipment its yours to do with what you wish. In XM equipment cases unless you use it to steal their signal I don't think they can say jack.
It will be nice to plug and play directly on the DIN jack, but what do you think the guys at Terk or Blitzsafe are gona have to say when you release this? They could claim infringement if they want since they are the only supplier to date for all the adapters. Blitzsafe applied for patents in January on a bunch of adapters.
BlitzSafe President and CEO."With the new advanced applications and Recent Patent Pending innovations by BlitzSafe such as Interoperable interfaces for Satellite Radio"
>Pending being the key word here
If anyone wants to void the warranty on a $50 direct or other receiver and disable or bypass the Amtel protocol conversion process so you can speak directly to the tin can in the same xm protocol as the PCR does. I say go for it.. While your in there pop in a toslink and your back to complete digital audio with TimeTrax compatibility. I'm sure the TT guys won’t mind if you do this. Plus if the word is out on a role your own fix,, less focus will be put on the plug and play fix.
NOS TANG is offline   Reply With Quote
Old 10-05-2004, 07:46 PM   #8
Bryan Pape's Avatar
Bryan Pape is on a distinguished road
Quote: Originally Posted by dacndar
Hello everyone,
You mentioned that this is an Atmel. Is it an AVR? If so, what kind of package. (I'll have to look at the XMPCR to see what it's using) Perhaps it's possible to reprogram with JTAG (from a parallel port). Additionally, it seems to me that figuring out the "proprietary protocol" used between the headunit and the XM Direct should actually be rather straight forward - i.e. If you press a button, what does it spit out. The nice thing is that the 8-pin din is already RS-232 instead of TTL. I would think that creating an interface in software should actually be rather easym.
Bryan Pape is offline   Reply With Quote
Old 10-05-2004, 08:48 PM   #9
Yes, it is an AVR Mega8 processor in the MLF package. The main problem right now is the Sony head unit I have was suppossed to be XMdirect compatible according to the list I had but I've since found out its not. So I have no way at the moment to manipulate a head unit to see what comes out. I have a PCR and I can tell you that there is no CPU between the input of the "can" and the PC. Only an FTDI USB to serial chip. The Mega8 in the XMdirect and the Mega32 in the "smart adapter" I have for the Sony head units are talking between each other to convert the head units protocol to what the XM direct is designed to speak. Then the the Mega8 inside the XMdirect talks to the "can".
Hope this clarifies.
Old 10-05-2004, 09:23 PM   #10
NOS TANG's Avatar
Sounds correct to me dacndar.
My question, and everyone else I have spoken to is, what the hell does that direct receiver talk on the DIN plug? This is the true $100 question. I have not seen a single HU out there that will work with it plug to plug. The only thing that I know it works with is the commander digital control interface. You said you have the smart adapter for your HU, have you cracked it open to play with yet? I would like to see the inside of one if you have any pictures. No wonder they sell the direct for $50 it's useless alone, you have to give the manufacture another $50 to just make it work.
My first idea was to flash the Atmel on the xmdirect board with a new protocol that we can work with as Bryan suggested. This would be a software fix vs hardware fix. Doing something down this line might be and easier solution unless someone can reverse engineer the existing “one off” protocol.
Old 10-05-2004, 10:06 PM   #11
Registered User
gork's Avatar
gork
While an internal modification of the type I propose (should it even work) will void the warranty, it will most certainly not bring legal action from XM. It is in no way worse than the digital audio modifications available nor the serial control modification for the SkyFi. I have two XMPCR units with voided warranties and "illegal" TOSLINK modifications that I'm sure nobody would have any problem with me selling for $500 on ebay. Do you intend to publish the XM Direct protocol when you figure it out? If I am able to find a solution that will result in wider compatiblity and lower cost, it's going to be published publiclly. I very seriously doubt that people will have trouble with voiding the warranties on a $40 device -- the mp3car community doesn't seem to have a problem voiding it on $350 LCD monitors!
MY CAR IS FOR SALE!
Old 10-05-2004, 10:21 PM   #12
Hers some pix 4 u.
Old 10-05-2004, 11:05 PM   #13
NOS TANG's Avatar
Thanks,
There is more crap on the adapter board then on the direct...
Notice that Atmel processor, now I know what they are doing? Same thing we are trying to avoid
Anyone??
Old 10-06-2004, 07:05 PM   #14
Bryan Pape's Avatar
Hers some pix 4 u.
OK, I'm at work now, so I can't check, but I'm interested to see what the chip is that drives my XMPCR. If it too is an AVR, then we might just be able to reflash the XMDirect with XMPCR firmware. Another interesting thing is the 8 pads in the upper right of DSC02196.JPG. JTAG maybe? If so, reflashing the AVR should be a breeze.
Edit: Scratch that... I just reread the first post. It seems as though the solution is to write a script for the AVR that passing anything coming in on one side to the out on the other. This should be pretty easy upon identifying which i/o pins on the AVR are used for input and output.... All this assuming that we can get JTAG access to the thing.
Old 10-06-2004, 07:14 PM   #15
Registered User
gork's Avatar
gork
There is no microcontroller in the XMPCR. It's simplay an FTDI USB Serial converter IC hooked directly to the XM module. Reflashing the microcontroller in the XM Direct is possible, but it requires hardware modification to get the thing where you can even flash it. If you're going to do hardware modification, just bypass the Atmel. There are a lot easier methods of completing this project than mucking with flashing the existing microcontroller.
A guy on the XM411 forums has PCR compatibility from the XM Direct already in a form that requires no modification of the XM Direct, but it remains to be seen what the future of his project will turn out to be. Hopefully a less expensive solution (even if it requires some simple modification to the XM Direct) will be determined since this interface is not going to come super cheap!
MY CAR IS FOR SALE!
Create our own XM receiver since the XMPCR is done with? judoGTI General Hardware Discussion 31 09-04-2004 04:33 PM
Let us write to XM Radio regarding XMPCR kingtut Car Audio 7 08-31-2004 10:23 PM
XM PCR External App dug1967 MediaCar 31 08-04-2004 11:35 AM
homebuilt XM receiver stevewm General Hardware Discussion 2 07-14-2004 02:00 PM
XM radio XMPCR Mr24play ME Archive 0 06-19-2003 12:01 AM
