Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-06-2004, 06:54 AM   #1
corsamel
7" screen just 2 small
Well finally got my 7" VGA touchscreen (lilliput). How do all you guys manage to read any of the text on windows. I'm thinking my eye sight can't be that bad can it.
The touchscreen overlay doesn't help (doesn't excatly give a crystal clear look) but all the fonts are just too small for me to read while sitting back in my seat. I've got XP Pro, adjusted the font size for the desktop and start menu items and this helps slightly but with everything else its just too small to use sensibly.
I'm looking into GPS software now and have currently got mappoint going and its just the same for this.. Can hardly read any text and if I increase the font size on the map it becomes too big for the roads.
Its seems to me that incar pc seems to be limited to using a purposely built software like Media Engine which is a shame. Just hoping that I can find a GPS solution to be able to use with ease on my 7" screen.
How does everyone else find controlling Windows on a 7" sorta size screen... I haven't got room for a 14" in my dashboard you see.
Volvo C70 - Installation in progress *gulp*
corsamel is offline   Reply With Quote
Old 10-06-2004, 07:08 AM   #2
carpcnoobie's Avatar
carpcnoobie is on a distinguished road
I'm assuming your Lilliput is hooked up thru your VGA and not the RCA.
I have the DPI set to 120 and that makes everything more legible. I can read the desktop files clearly. I use Routis and this also seemed to help with reading the street names in Routis as well, which I was having a difficult time at the default 96DPI.
Also, what is your resolution set at?
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 10-06-2004, 07:54 AM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I have the 7" lilliput in the dash currently running at 800x600. I use MediaCar as the front end, and this is fine.
However the normal windows screens and text are pretty small, but readable, especially since I have moved away from a TV screen.
It's kinda of difficult to use the touch with the windows side, but I will be moving to 800 x 480 when I put the new PC so hopefully the windows text will be more readable and TS friendly.
Enforcer is offline   Reply With Quote
Old 10-06-2004, 08:17 AM   #4
Power_nisse's Avatar
Power_nisse is on a distinguished road
Im planning of a Carputer project.
But im worried about the tft touchscreen im planning to buy.
Lilliput 7" VGA Touchscreen
or
Lilliput 8" VGA Touch Screen TFT LCD Display
The 7 tft has widescreen that makes a better picture and have better resulution.
But the 8 tft seams to become mouch better look and bigger screen size of course.
The different between 7 ftf and a 10.4 is HUGE. so why not a 8 tft =)
What do you people think of my thoughts?
Power_nisse is offline   Reply With Quote
Old 10-06-2004, 08:36 AM   #5
corsamel
Yep, I had a RCA screen setup before and that was hopeless as they are but this VGA setup is just too small.
I tried setting the DPI to 120 and it helped slightly but still not easy to read.. I can't keep it that setting anyway as Media Engine complains about it when loading.
Old 10-06-2004, 08:53 AM   #6
electron is on a distinguished road
Since this is an LCD, did you try enabling ClearType in under 'effects' in the display appearance options? It would make the font look much cleaner, and easier on the eyes. I have no problems at all with my 7" Xenarc TSV, and I still have the original protective plastic on the LCD.
electron is offline   Reply With Quote
Old 10-06-2004, 09:06 AM   #7
wizawuza is on a distinguished road
as carpcnoobie asked, what's yoru resolution set at? If it's 1600x1200, that'll make it hard as hell to read.
Try 800x600 or something..
wizawuza is offline   Reply With Quote
Old 10-06-2004, 09:26 AM   #8
SnyperBob's Avatar
SnyperBob is on a distinguished road
Depending on what you are trying to do, you could use the built in Windows magnifier to aid in viewing small stuff on the screen.
Also, you said you can't fit a 14" screen in your dash - you could try something smaller like a 10.4 inch screen.
You can find them pretty cheap, and they work better for working in windows.
check ebay, there are some deals out there
example: http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
I'll agree with you on the 7 inch screen - they are decent at running video and playing music, but not the best for GPS or working in windows straight up.
SnyperBob is offline   Reply With Quote
Old 10-06-2004, 09:40 AM   #9
corsamel
Wasn't aware of that option.. will try that. cheers
Old 10-06-2004, 09:42 AM   #10
corsamel
Missed out that bit... yep its already set at 800x600
Old 10-06-2004, 09:43 AM   #11
corsamel
Well... I can't fit any bigger than a 7" at the moment, unless I completely hack away my dashboard which i'm not wanting to do.
Old 10-07-2004, 05:08 AM   #12
Hey guys.. take a look at this one!
8" TFT LCD monitor with TV tuner" sounds really good in my ears.
But i guess you connect the computer along this connection...
-> 2 x Video in (two channels)
If so this mght me a very good option.
What do you think?
Old 10-07-2004, 05:16 AM   #13
Ohh forgot the adress =)
http://www.allcam.biz/products/518gl-80tv.html
Old 10-07-2004, 05:21 AM   #14
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
Take a look at what?
If I only have the info you provided, I'd say no. Composite will nog give you a good image. You need vga to get good readable text.
@corsamel: just do not use windows front-end on it! Seriously, all the carpc front-ends are made, just because you wouldn't have to use explorer and the likes.
Joachim
JC-S60 is offline   Reply With Quote
Old 10-07-2004, 05:25 AM   #15
krog
No vga input and bad resolution. I wouldn't use it for anything more than watching tv...
krog is offline   Reply With Quote
7" LCD Screen that's under 1" thick? TDIGuy04 LCD/Display 4 09-19-2004 03:19 AM
FS: TM-702L (7" in-dash screen, used) audrenaline Classified Archive 1 04-28-2004 10:19 PM
7" touch screen orientation bjohn Input Devices 1 10-11-2003 06:29 PM
What screen to get, a little bigger then the usual 7".... Seabass LCD/Display 18 08-10-2003 05:16 PM
7" screen, which mobo/gfx to buy for 16:9 TV out? Vittel LCD/Display 12 08-08-2003 01:15 PM
