Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-09-2004, 01:39 PM   #16
Arathranar is on a distinguished road
So not a case I could buy andput my micro atx m/b in then?
Arathranar is offline   Reply With Quote
Old 10-09-2004, 01:44 PM   #17
m3rdpwr
It is micro-atx, just low profile.
Meaning you can't put any tall pci cards, just low profile.
Big heatsinks may be a problem as well.
The power supply in mine was about 150watts and very picky...
-Mario
m3rdpwr is offline   Reply With Quote
Old 10-09-2004, 02:19 PM   #18
So where could I buy it? It looks smaller than the ones I've been seeing.
Old 10-11-2004, 09:54 AM   #19
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
I bought it off of ebay. Its an ITX or Micro ATX case.
http://cgi.ebay.com/ws/eBayISAPI.dll...713165544&rd=1
$35 bucks. My only complaint is there's no plugin on the power supply for a floppy drive. I got around it by making an xp boot cd.
And btw, i thought you meant you had an nissan not a chrysler. I drive an 01 altima.
Old 10-11-2004, 09:59 AM   #20
m3rdpwr
That's wacked, your dashboard looks almost identical so I figured you had the LHS. My case however is identical and it had fdd and multiple hdd connections. Guess that goes to show you that even if things may look the same, they can be very different...
-Mario
Old 10-11-2004, 10:14 AM   #21
starfox's Avatar
starfox
- I have the sound output coming directly from the on board sound card via rca-headphone jack converter. When my subs hit, the display bends. Grounding issue?
- Will using S-video instead of RCA's help at all with clarity? I've seen that composite is limited to 240lines, what is the limit with S-Video?
-Lastly, is there a way to connect a switch that would allow soft shutdown or hibernation? There is a button on my keyboard that does this.
Display bending might be due to the voltage dropping due to the subs hitting? If that's the cause you can use a capacitor to fix that (use this as a last resort though), adding thicker wire will probably help a lot too.
S-Video will help with clarity because the luminance and chrominance aren't munged together in the signal. I don't think composite and s-video have a line limit afaik.. there's some sort of bandwidth limit though... i think with svideo it's roughly equivalent to 1080i scanlines?
Switch to allow soft shutdown / hibernation? you can set your atx power button to hibernate on push in power options in control panels, that might be sufficient?
starfox is offline   Reply With Quote
Old 10-11-2004, 10:29 AM   #22
Terminal flasher
The Bending i solved by running the monitor power wires to the psu, then grounding the case. The S-Video helped clear up the images. I'll have to check the control panel options. i didnt know that was available. Thanks!
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 04:37 PM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 04:03 PM
Nissan Sentra 1996 GXE Complete Project. 14'' Screen criterzzz Show off your project 19 08-01-2004 01:07 AM
In Dire need of help (install complete but...) infernos General Hardware Discussion 1 05-05-2004 09:26 AM
screen install complete...I think! :) detz General Hardware Discussion 3 07-15-2002 11:15 PM
