When I pulled my old ibm laptop apart, to scrounge the lcd, hard drive, and cdrom, i found that the adapter I had bought to use the hard drive wouldn't fit. Mine had the adapter you mentioned, so i was very easilly able to hook the hard drive up, once I got the courage to unscrew what I thought was the hard drive, but was really just a plastic case. Now, here's the part that might interest you: I still have that adapter, and it looks (I say looks 'cause I'm not sure from the pics) like that adapter might fit into the the top drive and convert it into a normal connection. If you could take more pics I might be able to tell further, if it looks like it might work, I'll tell you, and if your in the US I'll mail the adapter to you. The only problem with this approach, even if it does work, is that you will will have a female output where you need a male, but that's a step in the right direction.
