Quote:
Originally posted by moahdib:
<STRONG>How would you tell winamp to send the sound to the USB port instead of a sound card? does this come with drivers of some sort? I don't understand what the USB port is for</STRONG>
Taken from the Nitty Gritty at Crutchfield:
Quote:
USB Input: The USB input allows you to connect a laptop computer to your car stereo system (USB cable not included) in order to play MP3 files or other audio from the computer. The computer must have a compatible operating system in order to work. It must be running Windows 98 Second Edition, Windows ME, Windows 2000, or Mac OS 8.6 or later. (Sony recommends Windows 2000 or Mac OS 9.0 or later)
All MS OSs past 98 have native USB sound drivers. I imagine once you connect to the xa-300 via USB, you'd get a "USB Audio detected." Then in the control panel, you specify that the usb sound device be used for playback.
By default, winamp uses the Wave Mapper for the Wave-Out plug-in, so no configuration should be needed if the USB sound device is the default playback device. If that isn't the case, then you could specify that winamp use the usb device under Prefs > Plugins > Output > Wave-out
If you can score a pair of labtec 1040 (i think that's the right model) usb speakers, you could do this yourself. Gut the speakers, and use the USB->analog audio board to connect your USB PC to your head unit input or source switcher.
Let me look for a page i read long ago for the details about this....
bam!
http://users.technocraft.com/~dune/usbaudio.html
[ 10-25-2001: Message edited by: koulouty ]
