Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-07-2004, 12:41 PM   #1
blazinlow is on a distinguished road
Electronics Question - Parallel Relay
Hey guys,
Im trying to build a very simple single relay card for just an experiment using this design:
I have built the circuit but I am having some problems with it- its not working!!
From what I can tell from this schematic, the + pin 2 on the parallel triggers the transistor, feeding ground from pin 18 to the relay, activiating it. I have a 12V source on the other side of the relay coil.
I am getting 3.3V coming off pin #2 on the parallel port. Ive used a multimeter on various parts of the ciruit to try to figure out why its not working.
Also, Im using a reed relay if that matters.
When as soon as I hook the 12V source to the relay coil, it trips - i get continuity between the in and out on the relay. When I put my + probe on the 12V source, and - probe on the ground, i show about 7V, which I dont understand becaue the parallel port is set to off. This is why the relay is engaged.
I cant figure this out, Im about to give up, so if anybody can throw me some ideas that would be great. Thanks!
Epia MII12000 | 512MB RAM | ATI TV Card | 60GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | WinALDL hookup | 10.4 Datalux LMV10R | Opus 150W PSU.
blazinlow is offline   Reply With Quote
Old 11-07-2004, 01:39 PM   #2
brooksware2000's Avatar
brooksware2000 is on a distinguished road
1. Do you have pins 18-25 on the parallel port grounded to the ground of your transistor?
2. Are you making sure that the port is addressed correctly i.e. 0x0378 for port 1?
3. What voltage are you using to energize the relay coil?
Take a look at my site in the signature and go to the projects section. There is an example there of a relay controlled H-bridge. Just use half of that design and it should work.
Check out my hopefully useful site...
www.hobbybotics.com
It's still under design but it is functional
brooksware2000 is offline   Reply With Quote
Which wire is power and which is ground in Inverter on/off switch. Relay Question. wonderworm Power Supplies 13 09-20-2004 07:01 PM
12V relay + diode question cybermob2 Power Supplies 9 05-18-2004 01:11 PM
Relay question lopan Power Supplies 2 02-25-2004 10:17 PM
Linux parallel port relay control? robiewp Software & Software Development 1 02-25-2004 02:38 PM
Will someone help me program my relay control module cproaudio Software & Software Development 6 09-04-2002 05:50 AM
