Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-20-2004, 04:45 AM   #1
PThomas is on a distinguished road
Advice on new laptop install for newbie
Hi all
I have a HP Omnibook 6000 which has a broken screen mounting bracket, an ideal candidate to go in my car !
I have removed the 15" screen leaving a 26-way cable connector. Has anyone tried extending a laptop screen 2-3m away from the laptop ?
I appreciate I haven't the space to mount the screen permenantly in the front of the car but thought I'm make up a way of having it quickly removable for security. Besides I can't afford to buy a new monitor.
The laptop has a built in DVD player so I should be able to play DVD's back in the car as well.
I was hoping to run the audio output from my laptop into my Sony head unit but looking on the internet I would need to spend £100 to get a line-in unit for the headunit !!
Has anyone done anything similar and have any suggestions ?
PThomas is offline   Reply With Quote
Old 11-20-2004, 04:50 AM   #2
Matthew230 is on a distinguished road
Quote: Originally Posted by PThomas
Hi all
Have you got a CD changer ?
Matthew230 is offline   Reply With Quote
Old 11-20-2004, 05:05 AM   #3
Fox_Mulder's Avatar
Fox_Mulder is on a distinguished road
People I think have tried to extend the laptop monitor however it tends to loose quality the further you get due to the fact it was never designed for that sort of distance. Also 26 wires that is gonna be a big cable
There are other methods for hooking up to a headunit such as down the ol' FM route. And depending on where you mount the laptop you may need to extend that dvd drive away from the laptop, using like for example an extended ide cable or ide to usb adaptor and running a usb extension.
[edit]
Also for a startup solution I recommend using a docking station and soldering 2 wires to replace the switch on the docking station to a relay and using some circuitry to turn it on if it is not already on. There is a schematic of this lurking in the hardware section of this forum.
[/edit]
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
Fox_Mulder is offline   Reply With Quote
xp install to laptop hdd problem thecrow Newbie 8 06-15-2005 04:37 PM
first post - boxster install, need advice... chris in nh Newbie 6 02-28-2005 11:31 AM
Laptop Install Help!!! Inspiron8500 General Hardware Discussion 8 07-02-2004 11:21 AM
Need help with install of carputer using a laptop... slimcubby General Hardware Discussion 4 04-27-2004 01:55 PM
NewB Questions for Laptop Install PaulDePimp Newbie 0 02-09-2004 11:57 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
