Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-25-2004, 10:25 AM   #1
Cat Monkey's Avatar
Cat Monkey is on a distinguished road
usb hub issues please help
I have a bekin ubs1.1 4 port mini hub that i am plugin into my m10k. If machine is on (booted), then u plug in hub it works, light flckers to idicate as much (I assume).
but...
Machine off. hub plugged in. Turn machine on, hub light stays solid. XP reports malfunctioning usb device not recognised?. Same thng happens on resuming from standby hibernate etc... Anyone know what the story is?
Cat Monkey is offline   Reply With Quote
Old 11-26-2004, 11:51 PM   #2
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
it probably isn't the hub, but something pluged into it. Try it with nothing, then one, then the other. I have found some periferals don't like to be on a hub, hd's & sound cards in particular, may have to run certain periferals off the motherboard usb, hope this helps...
turbocad6 is online now   Reply With Quote
Old 11-27-2004, 08:38 AM   #3
Cat Monkey's Avatar
have been experimenting with different bits and pieces but the thnig is jst a POS IMO. Thanks anyways
Old 11-27-2004, 09:44 AM   #4
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Yeah, cheap hub. I'd say get something different/better. Maybe even a USB2.0 hub. It'll still work with 1.1
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Hub does not show HD after cold boot d_sellers1 General Hardware Discussion 9 04-05-2005 02:46 PM
USB HUB problems???? chuckctv Input Devices 7 10-08-2004 12:38 PM
Powering an unpowered USB hub? Squiddy Input Devices 5 09-02-2004 05:37 PM
