12-02-2004, 09:27 PM
#1
Raw Wave
Vehicle: Chevy Van G20 and '06 Scion Xb
Auto Engine Start without A PC
Has anyone ever thought of this before once i get my carputer working in the middle of the winter leaving the computer in hibernate seems like a bad idea.
The Problem: My van at work is parked away from the building i work in. so my auto start does not reach (the remote signal) in the middle of the winter id like my auto start to automatically warm up my van monday thru friday at 9pm for when i get out at 930
SemiSolution: I thought why not have my carpc do this job it would be not all that hard maybe with phidgits i dunno BUT with real cold temps i dont wanna damage the computer at low temps for ex The HD
So: can this be accomplished without a pc any ideas (aside from that machine peewee herman used to have )
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
12-02-2004, 09:34 PM
#2
Vehicle: 2001 Jeep Cherokee
Nice. Someone with a van. I'm more of a Ford van man myself, but hey - it's a van!
I'm going to take the lazy way out and install a long-range car starter with an accessory trunk popper. Hook the popper up to a relay to start the 'puter.
Where are you located? I've had my 'puter in MN for several years and the thing still works fine. Granted, I usually let the car warm up for 1-2 minutes before turning on the computer...
12-02-2004, 09:37 PM
#3
Raw Wave
NewYork
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
12-03-2004, 11:13 AM
#4
Raw Wave
any suggestions?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
12-03-2004, 11:25 AM
#5
Vehicle: 2007 Scion tC
I have a Viper Remote Start Alarm in my truck. It is made for long range and it works 1/4 mile away. Just get that and save yourself some time/money in the long run. Cost me $500 installed.
12-03-2004, 09:17 PM
#6
Raw Wave
range isnt the problem its timing
I want it to go on automatically each night around 9 or so
how might I accomplish this ?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
12-03-2004, 11:04 PM
#7
Use an ATX DC-DC ps and have the computer turn on automatically just before 9pm. (many bioses have a timed startup option)
Then have the computer trigger startup the same as your car starter:
Car alarms send a 12v signal through the same line your key triggers when it's in the start position. So a computer could do that easy enough.
The tricky bit is in determing when the car is started so the starter relay can be shut off. I don't understand the theory behind how auto starters figure it out (and I have a dead starter to prove it) so i guess I can't help you there...
12-03-2004, 11:14 PM
#8
Vehicle: 98 Ford
have your computer momentarily comlete a realy circuit connected to the button on your (spare) remote for your remote starter . Not exactly sure how to do this, but people have been operating relays with there computer for a while now to power there windows and ac systems, so I figure this can be done as well. Just a thought on where to start...
You can still have something if you have nothing
12-03-2004, 11:44 PM
#9
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
It is depend on the alarm and remote starter system. If the 2 are separate units (alarm by itself and add on remote starter), the remote starter system will have a (-) triggle input from the alarm module. If the 2 are integrated in 1 unit, I don't know.
When the computer auto start by time, wire a relay constant to pulse (in hardware development forum) circuit to triggle the remote starter. The circuit in show in the forum is for (+) pulse, but you can change it to (-) pulse.
12-04-2004, 03:16 AM
#10
Vehicle: 2001 Ford Ranger
the car starter doesnt have a constant flow of electricity to it, only when you turn the key the whole way over does the starter get juice.
Progress: | All materials Purchased...
12-04-2004, 04:03 AM
#11
My Village Called
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
Car starters while cranking look for engine RPM. If the RPM stay at a cerain range then it lets go of cranking.
12-04-2004, 07:13 AM
#12
Vehicle: Bravada - Triplet
How do you look for RPM?
12-04-2004, 07:45 AM
#13
I don't think (or I hope at at least), he meant the starter actually measured the RPM, since it can't. What perhaps he meant was the fact once the engine starts going by itself, the flywheel spins faster than the starter's pinion (the thing which engages the flywheel and cranks the engine), and since the pinion is a free-spinning device, the starter no longer actually keeps up with the engine.
With that said, you have a few choices at hand. Firstly, most car starters use a timed method. In other words, they don't shut themselves off when they figure out the engine is running, instead, it's timed for say 2 seconds, or 1 second, or what not--which is fine for fuel-injected systems. Some carbeurated systems require longer engages.
Secondly, for the few car starters which actually figure out once the engine is running, they can be hooked up through the ECU, or through a hot-wire which comes through the firewall. I forgot the name of the wire, but some (not all) cars have a line which goes high once the engine is running by itself.
So, with that in mind, you could do it via an onboard carputer, or through a basic electrical circuit. The onboard computer you'd setup to start itself up, just like was previously said, with one of the spare 12v lines engaging the starter's solenoid wire--PROVIDED the PSU on the computer provides ample power to the solenoid without causing a strain on the PSU.
Or, you could go with another popular method, build (or you can even buy) a basic timed circuit which throws a relay, and it all runs off of 12v which is native to your car. This is about a $20 option, and wouldn't rely on a computer.
12-04-2004, 10:27 AM
#14
Raw Wave
That makes sence but if its always pulsing its gonna keep trying to start the van...(or keep trying to make the remote start the van
ALSO the remote starter is stand alone i have to hold down both buttons to start the van, im sure i can look at my spare remote and make it a one wire trigger
I'm also assuming that this cannot be done without the aid of a computer. I was hoping so a small battery run curcuitboard set with a digital watch alarm could trigger a 4.5 volt (or whatever my alarm remote ran on) charge.. but unfortunatly im not an electronics major was hoping someone here might know how to ?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
12-04-2004, 12:30 PM
#15
Vehicle: 1981 Ford Granada Cardinal Hearse
you just want a battery alarm clock, take the wire that feed the beeper and use it to power the spare remote starter keyfob?
remember,
K.I.S.S
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
