Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-13-2004, 08:09 PM   #1
theheel is on a distinguished road
usb extensions and speed?
i have a bunch of those little 2 ft or so usb extension cables that come with those usb drives and other usb devices.
My problem is that the ide to usb drive adapter only has a 6 inch length for the usb. Will using several of those little usb extension cables reduce speeds over a 4 or 5 foot distance to where my usb hub is?
btw its usb2 not usb1.1
theheel is offline   Reply With Quote
Old 12-13-2004, 08:19 PM   #2
omar's Avatar
omar is on a distinguished road
I've successfully run 2 cables connected together = ~8ft without a problem (no dataloss, full speed). My USB drive was USB2. YMMV.
omar is offline   Reply With Quote
Old 12-13-2004, 08:26 PM   #3
Tainted Love
Cris's Avatar
Cris is on a distinguished road
No problems should appear under 5m. If you want more than 5m, you can get an acvtive USB extension wire. But, still, keep it clean, and run a single wire, not 30...
Cris is offline   Reply With Quote
Old 12-14-2004, 12:51 PM   #4
shauns is on a distinguished road
Hey guys im new here... ive been reading everything and just lerkign around. I to had this question about USB length. and per http://www.usb.org/faq/ans5/
Q1: How long of a cable can I use to connect my device?
A1: In practice, the USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches).
so a HD and CD it would be a high speed. you can go 16 feet =)
wo0t! my first post was a constructive one
shauns is offline   Reply With Quote
Found someting interesting on E-Bay!!! outragis Classified Archive 929 01-23-2006 09:38 AM
