Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 01-03-2005, 09:29 AM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
My Weekend of carputer hell!
Thursday afternoon my carputer bluescreened itself into the ntloader not found dos message. I figured a clean format would clear the disk of any issues, so i took the hard drive out of the carputer and added it to my home pc as a slave drive. Using a windows 98 boot disk i fdisked and formatted /s. I put the drive in the carputer again and it wouldnt boot . Well after about 6 hours of fdisk/formatting with either the boot disk or partitionmagic the disk STILL wouldnt boot for itself. I ran the disk through 3 or 4 extensive diagnostic programs and they came up with nothing wrong with the drive. This leads me to 2 scenarios
1. My carputer was attached to the top of my sub box, and someone after 4-5 months of use the magnets finally ate the drive. Well... at least the boot section of the drive.
2. The win098 boot disk im using isnt formatting properly, neither is partitionmagic.
The drive will read/write just fine it just wont boot!
Soo... the secondary drive that was originally in my home pc was officially designated the replacement drive for my carputer. Its already formatted with fat32 so i figured i could use the boot disk sys.com command to transfer the system files to it and that would be all i needed to do. Well after doin that I get the General drive failure message. It can no longer READ the drive . I plug it back in as the secondary and AGAIN it can read/write just fine.
What are the chances that TWO drives that i bought as new have dead boot sectors within 5 MONTHS of purchase. Both of them are under warranty but dammit i want my carputer back!!! Luckily i found a damn good data recovery package that found about 75% of my music and important files off the pc. Anyone have any ideas on where to start first here?
Old 01-03-2005, 09:43 AM   #2
tejesh83
Have you checked the IDE cables? Even a small nick on the cable can cause HD instability.
tejesh83 is offline   Reply With Quote
Old 01-03-2005, 09:52 AM   #3
dingofarmer's Avatar
dingofarmer is on a distinguished road
did you setup a new master boot record? Holds all the links to the partition, could be currupt.
at the prompt c:\ type fdisk /mbr.
Do this before you install anything though.
dingofarmer is offline   Reply With Quote
Old 01-03-2005, 09:52 AM   #4
Terminal flasher
i tried booting the carputer drive in both my home pc and my carputer. I guess i can try switching the ide cable but i dunno if that is my prob.
Old 01-03-2005, 09:54 AM   #5
Terminal flasher
I did NOT try that. I tried to do it via xp repair utility but it didnt seem to do anything just went back to the c prompt. I'll have to try that tonight. Thanks!
Old 01-05-2005, 04:14 AM   #6
BeaverWise's Avatar
BeaverWise is on a distinguished road
How did it work out?
BeaverWise is offline   Reply With Quote
Old 01-05-2005, 04:18 AM   #7
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
yeah defo sounds like the MBR.. stick it back in your home system and do what dingofarmer said.. if that dont work, its goes in the bin
CdRsKuLL is offline   Reply With Quote
Old 01-05-2005, 04:43 AM   #8
Yuriy's Avatar
Yuriy is on a distinguished road
Bad RAM could be causing it. I remember getting very frustrated over a similar problem just to find out my RAM was corrupting the registry. Just do a bios check on it and see if it gives you any trouble. Otherwise, try booting from that hard drive on a different system, this will help you identify whether it is a hardware or a software problem.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 01-05-2005, 05:42 AM   #9
Gavc is on a distinguished road
how can the hdd boot after a format without reinstalling the operating system to boot ?
Gavc is offline   Reply With Quote
Old 01-05-2005, 05:54 AM   #10
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Make sure when fdisking the partition has been made 'active'
Enforcer is offline   Reply With Quote
Old 01-05-2005, 09:19 AM   #11
Terminal flasher
ok problem solved. I tried the MBR trick and it didnt work. turns out when i fdisk'd with partitionmagic it made the partition an extended and not a primary. I completely overlooked this when displaying the partition settings. I managed to get xp on. service pack 2 on and so far there has been no more probs. Now i just have to recover about 10% of the mp3's i had on there that getdataback didnt seem to find. Thanks for your help guys!
99 Acura TL carputer project pics Darkshear Show off your project 15 08-23-2007 01:14 AM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
(Div)XBox Carputer (warning: many pics) Richie Show off your project 41 09-01-2005 06:24 PM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 06:34 PM
Thinking of selling my old carputer for an ipod churnopol General Hardware Discussion 2 10-15-2003 11:10 AM
