Quote: Originally Posted by FyreDaug
Too bad Ive got an xp3000 barton core I think
I'd give the Barton a shot, it depends entirely on when it was physically manufactured.
Quote: Originally Posted by haileris
I don't believe you need a motherboard that supports multiplier changes if you do the wire trick
If your board doesn't support changing multipliers, the board will defailt to the lowest multiplier it supports (which you would have no say over) and the chip will run at something like 800 Mhz.... however slow that my be, it would certainly run cool.
Technically you can shot pins like crazy...but!... it's hard and doesn't
always work. It is very fine work, but requires no soldering. You
MUST make sure to properly seat the CPU in the ZIF or you run the risk of your HSF not fitting properly and overheating (which may not be a huge problem for underclocking)
This link shows the technique for wiring pins. It's not applicable to you, but the technique is the same... see haileris' link for the propper pins. I've never been to that site so I cannot attest to its accuracy.
