Quote: Originally Posted by wizardPC
That setting is meant to turn the computer back on when the power comes back after an outage. Basically, when it sees power, it turns itself on. If you shut the computer down, unplug it, and then plug it back in, the computer will turn itself back on automagically. This is effectively what you are doing with the rocker switch going to the 12v supply.
Wow, I didn't even know this MB has this feature...awesome info, thanks alot. Makes things ALOT easier! One other question, do you think the 12v power supply has a regulation circuit? If I wanted to just add a regulator to the 12v input, what would you suggest?
