Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-16-2005, 09:32 PM   #1
pirate_king00's Avatar
Wiring question
Ok, quick question. How are you guys wiring up the power to the XM direct unit, Creative sound blaster audigy, and usb hub? Are you wiring directly to the ignition switch or putting in your own 12v switched power. ALso what gauge of wire?
Just trying to decide what to do with my install this weekend. I dont need electrical problems in my 2003 Dodge.
pirate_king00 is offline   Reply With Quote
Old 02-16-2005, 10:15 PM   #2
strohmrs's Avatar
It's best to only use the ignition switched line to power a separate 12V automotive style relay and feed the relay with fused battery power. The ignition will turn on the relay and power all those devices just as if connected to the ignition line but without the worry of overloading it.
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
strohmrs is offline   Reply With Quote
Old 02-16-2005, 10:44 PM   #3
ppgt94's Avatar
You can usually get away with just tapping into the 5V and 12v rails from your powersupply. That's what I did. I'm powering a 7" Xenarc, USB hub, remote located slimline dvd/cdrw drive, and of coarse the main compuer components inside the case off my Opus 150.
ppgt94 is offline   Reply With Quote
Old 02-17-2005, 02:01 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
For XM, I tapped off my PSU.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Question about Switchs and Wiring PapaPrem General Hardware Discussion 8 02-12-2005 01:42 AM
Carputer to Car Audio Wiring Question Obike Car Audio 2 01-13-2005 06:42 PM
Wiring harness question aegray Car Audio 9 01-10-2005 03:28 PM
Wiring question barometer Newbie 2 07-14-2004 05:35 PM
Silly question about Wiring SuperMatty Power Supplies 8 02-10-2002 01:23 PM
