Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-17-2005, 03:13 PM   #1
J-Fame is on a distinguished road
Mobile CPU VS Conventional CPU ??'s
I was under the impression that mobile CPU's worked exclusively with laptop motherboards. Is this true? Or would I be able to buy a regular mATX motherboard (Socket A) and then use a mobile AMD CPU? If someone could help me out soon that would be great as I have an opportunity to get the mobo I was looking at for a great price. Thanks in advance
J
J-Fame is offline   Reply With Quote
Old 02-17-2005, 04:11 PM   #2
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Dude, i would explain but i am off for dinner....i odn't meant o be nasty but please search for these terms...
mobile athlon (obviously)
wire mod
Biostar
MSI
Epox
and you will find some posts that have talk of mobile athlons
Also look up the recent(ish) thread titled "Intel or AMD" or summit like that.
MatrixPc and a few others run mobile athlons. The onlt board so far known to be able to run one without any dodgy mods is the biostar as if has full fsb and mutiplier control. The AOpen one in a thread i started today might - gonna do some more digging around for info on it.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 02-17-2005, 04:39 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You can get a mobile CPU. Check your motherboard specs to see if it will support a mobile processor.
The advantage to the mobile CPUs is they draw less power. that means a less expensive power supply. That means less heat. That means more accessories you can run. That means less pull off your car's electrical system.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-17-2005, 04:42 PM   #4
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Yes, mobile AMD socket A work with regular desktop mobo with some little trick.
Search for "AMD Mobile" you will find some.
Look at my sig
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-17-2005, 08:23 PM   #5
Vicious is on a distinguished road
Hmm... interesting. I did not have to use any trick whatsoever with my mobile athlon. I have a Mobile Athlon 2500+ and a Abit Nf7-S that worked together right away. I overclocked it to 3200+ speeds right off because it could work at higher frequencies with lower voltage and heat as it was designed as a laptop CPU. Underclocking would be very simple too.
Vicious is offline   Reply With Quote
Old 02-17-2005, 08:33 PM   #6
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
but is it a mATX board?
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 02-17-2005, 08:40 PM   #7
kasemodz is on a distinguished road
here yo use this... I have a pretty good setup. I have a SOYO K7VME matx mobo and and amd athlon xp mobile 1400+. I'm pretty sure u could use other cpus as well. The soyo mobo is pretty good. It doesnt have 6 channel surround sound but u can always add it.
kasemodz is offline   Reply With Quote
Old 02-18-2005, 10:25 AM   #8
MySQL Error
MatrixPC's Avatar
For AMD only.
Most/all full size ATX mobo that allow "overclocking" feature, can use mobile CPU without any problem. The trick is you have to setup FSB and other stuff in BIOS.
For most mATX mobo with nForce chipset, the "overclocking" feature is NOT there. So you can't do the "easy" trick in BIOS. Instead, wire modded is one of the method to make it work.
I have that Soyo K7VME (flexATX instead of mATX). This board works fine with mobile CPU cuz you can select FSB by jumper. I bought this board as a package deal with the mobile CPU and only use to test if the CPU is working.
Celeron mobile cpu on a standard s478 board GuiltyLionel General Hardware Discussion 1 09-27-2005 04:05 PM
Careful to Mobile CPU buyers! false advertising! gospeed.racer General Hardware Discussion 16 06-04-2004 05:08 PM
