The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 02-18-2005, 02:35 PM   #1
crazymadbastard's Avatar
Vehicle: 02/OOOODI/A6/6sp/twinturbo
My Photos: (0)
running tray dvd drive upside down in car.
Seems that the easiest way to mount my zpcgx is upside down( because of the cpu venting on the top ) I want to mount it under my rear deck. So, would the cd pop out if I run this upside down and sit a bump? hmm...
Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
crazymadbastard is offline   Reply With Quote
Sponsored Links
Old 02-18-2005, 02:42 PM   #2
MySQL Error
Scouse Monkey's Avatar
Vehicle: Pug 306 & BMW 325i
My Photos: (0)
How are you going to load the CD in the drive if its upside down in the 1st place?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 02-18-2005, 02:47 PM   #3
Vehicle: 2005 Subaru WRX Wagon
My Photos: (0)
get a laptop drive that "snaps" the CD/DVD in place... super cheap, you'll just need a laptop to IDE adapter (like $10)...
mgithens is offline   Reply With Quote
Old 02-18-2005, 03:02 PM   #4
Raw Wave
wizardPC's Avatar
Vehicle: $800 1995 Plymouth Neon
My Photos: (0)
or mount the drive upside down in the case so it's right side up when you mount the case.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 02-18-2005, 03:08 PM   #5
Vehicle: 92' GMC 2500
My Photos: (0)
wizard just a question, how so much debt???
bobs987 is offline   Reply With Quote
Old 02-18-2005, 03:23 PM   #6
My Photos: (0)
The case/computer they are refering to has the slimline optical 5.25 inch drive bay. Depending on how they are mounted, the drives are not symetrical. There is a step on one side. I had to totally make new brackets when I turned mine over, and rethink the mounting it of. Tray loader if the CD snaps in should be okay, a tray that it floats on would likely be too much trouble. I would probably work on making a new bracket and flipping it over.
Bangster is offline   Reply With Quote
Old 02-18-2005, 03:52 PM   #7
My Photos: (0)
The drive is the snap in type so I may be ok.
yes, I said the easiest way is to mount the entire ZPC upside down. I could mount the dvd upside down after figuring an entire mounting system for both the hd and the dvd drive. I already figured the wiring though.
I have an external dvd drive for the cabin and I want to keep one in the system for extra storage in the trunk. The drive to go in the trunk was ony $10 so I may just risk it.
Old 02-19-2005, 04:14 PM   #8
Raw Wave
wizardPC's Avatar
My Photos: (0)
Quote: Originally Posted by crazymadbastard
The drive is the snap in type so I may be ok...
Yeah, you're good.
I'M DEBT FREE!!
Old 02-19-2005, 11:31 PM   #9
Deviser's Avatar
Vehicle: 1995 Pontiac Bonneville
My Photos: (0)
Arrow
Hey crazymadbastard,
I mounted my zpc upside down in my trunk and its fine cd snaps in and out.
Check out the Pics HERE to see how I did it.
Deviser
In progress Carputer [////////||] IWill ZPCgx: P4 2.40Ghz, 512Meg, 40Gb, Xenarc 7" TSV, 5 1/4 slot DVD, 802.11g DWL-G132, Ebay BU-303 USB GPS, TMobile GPRS Internet, Custom made power controller.
HU-Alpine CDA-7897 Fantom Face XL AM/FM CD/MP3 Receiver.
Deviser is offline   Reply With Quote
Old 02-19-2005, 11:43 PM   #10
Vehicle: 2000 Subaru Impreza Outback Sport
My Photos: (0)
Nice looking power supply - how much current can it supply?
Arathranar is offline   Reply With Quote
Sponsored Links
Old 02-20-2005, 12:00 AM   #11
Deviser's Avatar
My Photos: (0)
Up to 3 amps from each output and it has five outputs.
The Voltage and current are adjustable. I have each of them tweaked to output just the right volts and amps for each device powered.
Deviser
Old 02-20-2005, 12:21 AM   #12
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
Hey deviser, would you consider building a custom power supply like yours to sell to me? I wanted to build my own, but never researched it enough to actually do it.
nice jub on the pc mounting, but Im not clear on the actual mounting to the case. your mentioning the aluminum spacers & the crushing stuff, so I'm thinking you may have long bolts all the way through?
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 02-20-2005, 12:49 AM   #13
Deviser's Avatar
My Photos: (0)
turbocad6,
Do you have a ZPC or some other type of carputer?
As to the bolts I used to secure the ZPC to the frame, no they don't go all the way through that would kill the ZPC.
You can't see in the pictures I posted but they are inside the 3/4 steel pipe frame on the top and bottom of the ZPC.
The shortest bolts I could find were # 4X40 and 10mm long that’s about 0.3937008 inch
I really did not want to cut them to make them shorter because I was afraid it would bugger the threads.
So with the aluminum spacers + 1/8" of the 3/4" square steel pipe + 1/16 rubber washer the bolt goes through then threads into the ZPC's aluminum case so the bolts avoid shorting the motherboard and crushing the cd-rom drive thankfully.
Deviser
Old 02-26-2005, 02:18 PM   #14
My Photos: (0)
Quote: Originally Posted by Deviser
turbocad6,
Deviser
Nice work!
I have a zpcgx 2.4ghx celeron-
How are you powering yours?
I have run it directly from the car's electrical system. Do you have a "how to"
build yours?
Old 02-27-2005, 10:47 PM   #15
Deviser's Avatar
My Photos: (0)
Nice work!
build yours?
I wanted good stability as far as power goes for my ZPC so I sought out a power adapter accustomed to the mobile environment matching the same output specs as the ac adapter. I ended up going with a Lind adapter. They are well known for manufacturing custom-made power supplies for laptops. Here's the model I used: LINK
I wired in the Lind adapter to the switched power distribution blocks pictured in my post above displaying my custom-made power controller. I plan to post my experiences installing my ZPC carputer and show off some of the other things that I have done. I have my own domain and will host a website devoted to my carputer project soon. At the moment, I prefer to concentrate on the remaining major elements of my project. However, if I find anything posted that would be of any help to anyone, I will post instructions and pictures as I did above.
It's nice to have a fellow ZPCer in the forum.
Deviser
Sponsored Links
vB code is On
Trackbacks are Off
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
Dvd and hard drive on same cable question zetecdan General Hardware Discussion 3 07-07-2005 12:16 AM
Using DVD drive oekundar General Hardware Discussion 1 12-06-2004 06:01 PM
Slimline IBM DVD drive up for sale mpattonm General Hardware Discussion 0 04-15-2004 03:30 PM
DVD ROM Drive External dimmensions... m3rdpwr General Hardware Discussion 0 01-12-2003 05:32 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
