Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-27-2005, 06:14 PM   #1
Audigy 2 NX left channel only issue? help needed...
OK, need some help with my audigy 2 NX external usb hub. I have double checked my connections and I can not figure out why I am only getting left channel audio. I have:
4 Channel Amp running front and rear
2 Channel Amp running subs
I uses y splitters too hook up right into the back of the audigy NX. The front speakers (both of them) play front left channel audio and both back speakers play rear left channel audio. ???? I test this with the Creative speaker testing program. I am thinking that maybe the y splitters are the issue. I am 99% sure I bought "Stereo" y splitters. Would this be a problem if I bought "mono" y splitters? i guess I am just brainstorming the problem. Anyone have any ideas how to fix this? It has to be somthing I overlooked...
My BMW 2004 330i
jedi7001 is offline   Reply With Quote
Old 02-27-2005, 07:12 PM   #2
Raw Wave
rando's Avatar
It definitely sounds like your cables are just standard mono Y-cable splitters -- which is not the cable you need. You need a cable that converts the headphone style connector into seperate L/R channels with RCA connectors. A stereo headphone connector will ALWAYS have 3 rings. A mono cable will USUALLY have only 2 -- though sometimes they have 3 also. To be certain, you can take a meter to the cable to check out how it is wired. Your description pretty much already confirms it though.
2004 4runner
rando is offline   Reply With Quote
Old 02-28-2005, 07:38 PM   #3
FIXED!!! Thanks a ton. I over looked this
My BMW 2004 330i
m10000 on-board -> audigy 2 nx -> m10000 on-board fatman Car Audio 7 02-21-2008 11:49 AM
Help me power my Audigy 2 NX from my Opus 150w imprezive one Power Supplies 1 01-15-2005 12:51 PM
Audigy surround 5.1out to 6 channel Amp !! GOOD lookinco Car Audio 19 11-25-2004 02:28 AM
Audigy 2 NX and Sub nick9871 General Hardware Discussion 14 08-18-2004 09:41 PM
Audigy 2 NX USB Nightmare gwlund General Hardware Discussion 6 11-12-2003 09:57 PM
