03-14-2005, 10:10 PM
#1
Laptop vs desktop
I can acrossed this site about a week ago and decided right there and then this is exactly what I'm going to do with my new Mazda 6.
So I spent the next week reading the overwhelming informations on this site and got a pretty good idea on how things are supposed to work. Now it's time to me to get down and start do all my plannings. Step 1, decide on a machine. It sounds a lot harder than it is. I've seem many laptop based carputers and desktop based carputers and they all have their advantages. So I came back on the site and did a search and surpsied to see that I couldn't find any thread that compares the 2 based carputers.
I'm starting this thread to get people's input on what you think are the advantages and disadvantages of a laptop based carputer and a desktop based carputer.
Here's what I think, please correct me if I'm wrong.
Laptop
pros:
- small size, easy to find a place to store the laptop carputer
- light weight, a heavy laptop if prob 7 lbs, much lighter than a avg. 25 lbs steel desktop box. More mileage for your gas, save more in the long run.
- easy maintenance. pop it, do whatever you need to do on the laptop
- portable. pop it, take it into starbucks.
- Less power hungry. Please correct me if i'm wrong.
- easy power setup. get a laptop car adaptor [thanks rushnrockt]
- Standby mode. Turn carputer on/off in 3 seconds. [thanks Goddy]
cons:
- more expensive startup cost. If you don't have a spear one, it'll cost about 400 to get a decent used one.
- harder to replace broken parts. If the machine broke due to overheat. It'll be harder to replace and more expensive.
- No good startup option. (This is bothering me. I havn't found a way to remotely start the laptop. A member with laptop based carputer needs to manually hit the power button. This is the biggest drawback to me. If you have a solution, please share, thanks.)
- less hard drive space. This is a big one, if you want to load 5000 mp3s + 1000 movies, you will need lots of space. desktop harddrives are big and cheap, laptop HDs are smaller and expensive. (more $$ issue) However, i must point out that most poeple use laptop HDs on their desktop based carputer because they produce less heat.
- doesn't have a true DC to DC power solution. Need to use a inverter.
Desktop:
pros:
- cheaper startup cost
- more info on this site because lots members are using desktop based solution
- integrate well with car's DC power
- auto startup (although I havn't figure out how, can someone point me to a right direction? thanks)
- more powerful. 1gHz + is normal. Although I don't see why we need so much process power. We are not ripping DVDs or rendering graphics.
- more flexable. You can load anything you want onto the PCI slots. However, similar addons are probably available for PCMCIA interface. Plus, we use most external USB devices. (GPS, DVD-rom, sound)
- easy upgrade options.
cons:
- big heavy case. Add dead weight to your car. If you want to go SFF, you'll have to pay extra
- need to buy a DC to DC power
- lots of wiring work to hookup power. maybe too difficult for noobies
As you can probably tell, I'm leanning towards using a laptop based solution. My only problem is the auto startup and get a get sound to my car. I'm looking to get an AUX-in to my HU to hookup sound.
My goal is to get a functional MP3/divx/DVD/GPS/NAV/Backup Cam carputer up for cheap. I have a old P2 366 which I spent last night installed winxp and configured it to startup in 40 seconds. The suspend time/wake from suspend are about 3 seconds each. I think it's pretty good. The inital 40 sec will force me to wait for my car to warm up at the beginning of the day,the I will take advantage of the suspend function to get my carputer system up in 3 seconds for the rest of the day.
I'm planning to get a PCMCIA/USB2, USB2 hub and hook up USB sound card to AUX-in and USB DVD player, USB GPS and a USB camera.
I'm interested to see what you think about this laptop vs desktop discussion. Please also voice you opinion on what you think about my plan. thanks.
03-14-2005, 10:19 PM
#2
A little wordy aren't ya...
03-14-2005, 10:57 PM
#3
Quote: Originally Posted by wei2cool
Laptop
pros:
- easy setup. All you need is a inverter. (but a problem if you want DC to DC)
cons:
1) There really isn't any need for a full case weighing 25lbs, SFF or custom made case would do much better.
2) Nope, don't need an inverter, since there ARE DC-DC solutions that are a hell of a lot smaller than an inverter with standard ac-dc adapter for laptop would be. Check out Belkin or Kensington for starters. So there is absolutely no need to use an inverter.
Desktop:
pros:
cons:
If it integrated that well with car's DC power, Opus would have more competition and the prices would be a hell of a lot lower. Laptop is better in that respect since it only needs to go from car power to one DC voltage, not several like the desktop.
And again, the case does not have to be large or heavy.
PS.
8car, that was an absolutely useless comment
I have found you an argument; I am not obliged to find you an understanding.
03-15-2005, 01:23 AM
#4
rushnrockt, you are right. I forgot there are 3rd party car power adaptor for laptops. That makes it even easier to intergrate a laptop carputer solution. I think the price is also cheaper to buy that instead of an opus DC power. That's another plus for the laptop and for me.
8car, that was very informative, thanks.
03-15-2005, 05:17 PM
#5
I have a laptop as carpc, there are a lot pro's more:
- standby!! wonderful! going to standby within a few seconds and start the carpc where you was within a few seconds without having to boot. It can stay for days on standby with a normal - good powersupply.
- can have a laptop with broken lcd so very cheap buying it second hand. a standard carpc needs very expensive ac/dc adapter + nonstandard mobo+cpu (mini atx etc.).
- all you need is good usb support so it can do everything a pc version can do (i admit a bit more limitations, but all you want is there)
03-15-2005, 05:24 PM
#6
Well, He asked for it.
one problem i had using a laptop is that, their is no easy way to make a start up / shutwdown controller work with it.
Now i have a M10000 in a case i made for $30 (plexi) that is 2"x10"x7" smaller and lighter then the laptop.
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
03-15-2005, 05:39 PM
#7
i gently ripped of the standby button, connected two wires on it with needles and got the wires in front of the car with a button. It sounds pretty much work but it isnt and worth a lot when you can use the standby function instead of powering it down and boot.
03-15-2005, 10:29 PM
#8
I used one years back - solderd wires to the on/off switch in
the laptop and ran the wires to the front seat - easy if you can solder -
if you cant dont even try - almost to small to see - worked great
- and on a lot of laptops there is a switch that works when you
close the lid - could use that with a relay to you acc - so it would
go into sleep when your car is not running
I have a laptop now that I could use if only my LCD would work with
it - it defaluts to 800x600 75hz - and my old datalux only does
640x480 60hz - so it just sits here  - it is a rebanged
Via Eden motherboard made for a laptop, its a Compaq 1200 12XL2
laptop with no lcd of its own - long story - got run over and busted
the LCD but the laptop still works
they sell small ones
Usb 2 IDE Hard Disk adapter, to use reglar hard-disks- and cardbus
usb 2.0 card to make it fast - or use firewire to be even faster
700mhz intel P3 is fine even 350mhz intel P2
or AMD chips if you can power them - but the VIA chips need to be
faster to do the multimedia bit - there fast at windows things but
slow at multimedia stuff - ie - a 350mhz intel p2 will play DVD and Divx
but a 600mhz Via CPU has problems doing it
If you look, you could
get one that cost half that, and a new one is not much more than $400
Its a lot of wires no mater what - make up some
images using ms paint or such of were the wires go to make it
easy-er to understand - and easy to install
03-16-2005, 08:01 PM
#9
[QUOTE=wei2cool]rushnrockt, you are right. I forgot there are 3rd party car power adaptor for laptops. That makes it even easier to intergrate a laptop carputer solution. I think the price is also cheaper to buy that instead of an opus DC power. That's another plus for the laptop and for me.
I got a Kensington DC-DC adaptor for about $80 @COMPUSA. It was a universal model , in that it had a fuse looking thing for different voltage needs. If I changed laptops, I could change the voltage to meet my needs.
I am currently using a convertable/tablet PC as a carputer. I realy like the stylus input. Next best thing to touchscreen.
One thing I have discovered (which many of you surely already know), is that I had trouble with an external harddrive, when powering it from the vehicles cicarette lighter socket. It kept stuttering when streaming MP3 files. I hooked up an aftermarket 12V socket assembly directly to the battery, and got rid of the problem.
Good post wei2cool....from someone else very new at this too.
thanx to experienced members for not making newbies feel like dumbies.
ROCK ON!!
03-16-2005, 11:56 PM
#10
mrshelf
can you elaborate more on how you run the power directly from the car battery to the external HD? I forget to include that part into my planning, and it seems to be a pretty important one.
03-17-2005, 12:22 AM
#11
sounds like the remote start is still the biggest problem for the laptop caruter.
I saw some replies on people rewired the laptop power/standby button to the front of the car, while this served the purpose it also removed one of the biggest advantage of the laptop carputer. That is you can't pop the laptop out and take it with you anymore.
I think the best solution is "wake on ring". when the car starts up, wired it so it will send the magic wake up packet to the laptop and turn on the machine. I saw someone claim that s/he had done this. I need to find out more. If you know how to do this, please share. thanks
"wake on lan" is a no go, since it requires an ip/mac address
"wake on mouse click" sounds like a good idea. All you'll have to do is touch the lilliput touchscreen to emulate the mouse click. However i have never seem this option in any bios and couldn't really find anything online either.
"wake on keyboard" is another option. However, this requires you to have to keyboard available at all times.
My laptop carputer supports wake on ring. i'm going to find out more and see if i can fashion something that simulates the "magic ring"
03-17-2005, 12:37 AM
#12
I could, but it was ugly, mine had quick disconect plugs on it
- you had 2 wires with plugs on the end of them hanging
out of the laptop - You could if there is room use a mini phono
plug inside the laptop - or maby use the MIC plug and rewire it,
but yes there is a way
03-17-2005, 03:01 AM
#13
03-17-2005, 03:11 AM
#14
Yeah, i know you could make it so it's detachable from the extension wire, but it would be ugly. i rather people think "gee, that kind of geek brings a laptop to starbucks?" than "gee, don't get too close, I might get electrocuted by the 2 lose wires sticked out of that laptop."
it seems to me getting a dockstation and rewire the power on the dockstation might be the way to go. This way, you can have the best of both world.
03-17-2005, 03:18 AM
#15
I opened my laptop up, soldered 2 wires to the power button and snaked them out the
back. Then I just put a plug on it to make it easy to rip out of the SUV if I need too.
I removed the screen from my laptop and sold it on ebay, so I'll never use it alone so
the wires are fine.
If you are using a laptop you want to take out and continue to use, a member back in the
day used a small r/c plug that he made fit in the side of the laptop and looked very clean.
I just did another laptop yesterday for a friend, and I ran the wires out of the docking
station port area, that has a cover so the wires can be hidden when removed.
As far as the remote start, you have many options... I made my own timer circuit so
it turns on and off with the key and has delays built in for startup and shutdown.
When we did my friends install, he just wanted to be able to control it by a button
on his dash, and that works out real well also.. you just have to make sure
you protect the wires coming off the switch with a relay so you don't fry the
laptop... (there is +5v on them).
I still think a laptop solution is cheaper and easier than a desktop imho
and yea docking station that you mod keeps the laptop virgin too...
CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
Display: Lilliput 7" TouchScreen
CarPuter Install
| Thread Tools |
| Display Modes |
Linear Mode
