The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-16-2005, 02:03 AM   #1
S11D336B's Avatar
Vehicle: 99' Lexus RX300
My Photos: (0)
Hard drive shock / vibration thoughts
The whole issue of hard drive failure must be broken down into the facts. Working with cars and airplanes with a few years has allowed me to gain some kind of knowledge in this field. There are two components we should be talking about when trying to protect a hard drive in a car. These are shock (half sine wave) and vibration (full sine wave). Shock occurs when a hard drive encounters acceleration and a sudden stop. Vibration is a continuous acceleration and deceleration oscillating from one direction to the other. To prevent damage from shock, increasing the mass of the hard drive by mounting it directly to the chassis of the car is a great idea. However, this does not help the vibration problem and will probably worsen it. So, what is really needed is a firm mount that accelerates with the chassis of the car when it encounters shock, but not so firm that it transmits the vibration inherent in any car to the hard drive. Some believe that going over pot holes only causes shock to occur. This is not true. Shock is the most significant force resulting from this. However, a noticeable amount of vibration can result. Listen to your car the next time it goes over a pothole. The clunk clunk sound you hear is shock. The rattle rattle sound you hear is vibration.
As far as the orientation of the hard drive is concerned. There are pros and cons to each. Mounting vertically keeps the heads from smashing into the platters, but may allow the heads to smash into the walls of the hard drive enclosure and read incorrect data. Gravity isn’t a factor at all in this because most hard drives are designed to be mounted either horizontally or vertically. Mounting the hard drive horizontally makes the head prone to smashing into the platter upon any kind of shock. However, this does keep the head from being moved by shock.
Vibration affects hard drives the same regardless of orientation. The direction of vibration varies significantly from car to car and situation to situation. This is caused by different speeds, cars, and road conditions. Because of this, only shock can be considered in the orientation argument, because it is the only constant factor with regard to direction.
So, excessive shock may cause read errors when mounted vertically causing a system crash. You restart the computer and everything is ok
But mounting horizontally will crash the hard drive. You try to restart the computer and it freezes / gives you errors and you have to buy a new hard drive.
Now that we know exactly what we are trying to dampen, maybe someone can come up with a design that does this best. IMHO a silicon or rubber dampener seems to be the best solution. Like the one found in the link below I use visco elastic foam (memory foam) on mine. It works well, but I do have a heat problem. This sort of deisgn would allow for better heat dissipation.
http://www.mp3car.com/vbulletin/show...rive+vibration
A rigid design that allows the hard drive to take on the mass of the car when experiencing shock, but not so rigid that it transfers too much vibration.
Hopefully I inspired someone somehow by writing this. . .
________________________________________________
Worklog
K7VTA3
1500+ Athlon 4 Mobile
510mb PC3200 DDR
ATI Radeon 7000 64mb
[||||||||||] 95% Complete
RentATechnow.com
S11D336B is offline   Reply With Quote
Sponsored Links
Old 03-16-2005, 02:23 AM   #2
vxcarpc's Avatar
Vehicle: 2002 LS1 Holden VXII Commodore Wagon
My Photos: (0)
I've had a maxtor 80gig hard drive sitting in a case tied down to the floor of the back of my wagon for more than a year and i haven't had a skip yet.. not one.. am i lucky? it's a normal 3.5 hard drive..
i also have sports suspension lowered over 1" all around so this will make the ride even bumpier.. In addtion I have 18" rims..
vxcarpc is offline   Reply With Quote
Old 03-16-2005, 03:47 AM   #3
Chuck's Avatar
Vehicle: 2001 Chevy S10 ZR2
My Photos: (0)
130,000+ miles in a 4x4 and no problems
2001 S10 ZR2
Chucks Skin
Chuck is offline   Reply With Quote
Old 03-16-2005, 01:15 PM   #4
koolaidkitten's CarPC Specs
Vehicle: 2001/Isuzu/Rodeo
My Photos: (0)
5 months in a Shuttle SFF box Sitting right in front of the Subwoofer enclosure. Not a hiccup.
I still think this whole platters crashing vibrations messing rotation with car direction is a bunch of myth hoopla.
koolaidkitten is offline   Reply With Quote
Old 03-16-2005, 02:01 PM   #5
Vehicle: Seat Ibiza Cupra
My Photos: (0)
Agreed.
There seems to be no pattern between orientation and damage to harddrives. I think all of the self-professed harddrive experts should shut the f**k up.
The only people that actually know the answers to these questions are the engineers that design and build the harddrives.
Engram is offline   Reply With Quote
Old 03-16-2005, 02:15 PM   #6
rubicon's CarPC Specs
rubicon's Avatar
Vehicle: 2000 Jeep Wrangler Sahara
My Photos: (2)
Chuck: How are your drives mounted - vertically or horizontally? (not immediately clear from the pic)
rubicon is offline   Reply With Quote
Old 03-16-2005, 02:15 PM   #7
My Photos: (0)
Shock ratings are 200-400 Gs for normal hard drives and 800-1200 Gs for 2.5" hard drives.
Is there any evidence that this isn't sufficient for normal (and even abnormal) operation in a vehicle?
ktritz is offline   Reply With Quote
Old 03-16-2005, 02:17 PM   #8
My Photos: (0)
Aren't those ratings for a powered down drive though?
I thought a powered up drives ratings were usually below 200.
Old 03-16-2005, 03:16 PM   #9
SOS
My Photos: (0)
My 3.5" is mounted vertically in a piece for hard-foam, in which I have cut a hole just a bit smaller than the disk (so that it will sit very tight), but I have only lowered it approx half into the foam, so that it will not overheat.
SOS is offline   Reply With Quote
Old 03-16-2005, 03:51 PM   #10
Chuck's Avatar
My Photos: (0)
It is on a 45-degree angle and the front of the drive is facing to the right with the ribbon cable coming out of the rear left.
2001 S10 ZR2
Chucks Skin
Sponsored Links
Old 03-16-2005, 03:59 PM   #11
rubicon's Avatar
My Photos: (2)
d'oh! I see it now. Are you using bungee cords to mount it like that?
Old 03-16-2005, 07:53 PM   #12
S11D336B's Avatar
My Photos: (0)
I think some of the specs that are given in this thread are a bit bogus. Here are the specs for an IBM 120GB 7200RPM DESKSTAR.
Environmental Parameters
Min Operating Temperature : 5 °C
Max Operating Temperature : 55 °C
Humidity Range Operating : 8 - 90%
Shock Tolerance : 55 g @ 2ms half-sine pulse (operating) / 350 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance : 0.67 g @ RMS (random) (operating) / 1.04 g @ RMS (random) (non-operating)
Sound Emission : 31 dB
http://www.memorysuppliers.com/ibm1272desid.html
So, 55g OPERATING 350g NON OPERATING for shock.
So, data shows orientation of the hard drive may not be a significant factor as it can take 60Gs of shock without failure presumably in any orientation. Getting a hard drive to experience 60Gs of shock when mounted to a 2500 pound car is a feat. The accident that caused Princess Diana's death was 70Gs. So, I eat my words, happy? However, it is only because of the weight of the car that the force was 70Gs. A hard drive which weighs say, one pound, dropped from one foot would experience far more force than this. Thus anchoring the hard drive to the car firmly is imperative.
Vibration tolerance is only 0.67g OPERATING and 1.04g NON OPERATING.
This shows that vibration IS a significant factor. Cases where people are mounting their hard drives rigidly to their car without failure may not be experiencing much vibration. However, this is definitely something the hard drives are prone to failure from.
So like I said before, mount your hard drives in a mount that is rigid enough to take on the mass of the car, but not so rigid that it transfers vibration. This gives the hard drive the greatest possible chance of survival in any condition.
Worklog
K7VTA3
510mb PC3200 DDR
RentATechnow.com
Old 03-16-2005, 08:11 PM   #13
Vehicle: 2001 GMC Sierra
My Photos: (0)
This is not exactly what you are looking for, but It shows a dampening concept that I have found to work quite well. I use it in my motorhome, which is verry vibration prone going down the road.
I think with some creativity, this concept could be adapted for harddrive suspension.
Just need to build an appropriate frame work
mrshelf is offline   Reply With Quote
Old 03-16-2005, 09:54 PM   #14
rubicon's Avatar
My Photos: (2)
Wow, oldschool. But if it works..!
Old 03-17-2005, 11:12 AM   #15
crazymadbastard's Avatar
Vehicle: 02/OOOODI/A6/6sp/twinturbo
My Photos: (0)
I say buy an 1:10 scale rc car and mount the hard drive into the car. That way you can have 2 suspensions, your car's and the rc vehicle's. Crazy, but it should work .think about it.
Iwill ZPCgx 2.4ghz cel, 256mb pc2700, external combo drive, 80gb 2.5 laptop drive, xp pro, usb gps, 7 in Lilliput TS , carnetix CNX1900. All mounted ghetto- still experimenting and tweaking.
crazymadbastard is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hard drive upgrade problems :-( Arex General Hardware Discussion 10 04-29-2006 12:53 PM
Can I boot from a removable USB Hard Drive? Jackboot General Hardware Discussion 8 11-12-2004 02:43 PM
Problems with EBAy kiosk and hard drive? davcd3 General Hardware Discussion 6 08-12-2004 04:08 PM
carputer hard drive died in 3 days therussman2002 General Hardware Discussion 16 08-10-2004 01:49 PM
Hard Drive Mounting / SAVE the drive! DerekR General Hardware Discussion 20 03-11-2004 08:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
