Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-22-2005, 01:43 PM   #1
Rundell's Avatar
Rundell is on a distinguished road
Docking Port For Entire System
Figured I post some pics of my new creation. With this docking port I have, VGA, Serial, 2 external USB, 2 internal USB. I just got done with some testing and everything works!
I still have to add some things like power, 12V out and 5V out, not a big deal got the hard part done. Also I might be running the ground through it, but need to test it to make sure I don't get any soundfeedback or anything, otherwise its seperate.
This will make it so I can take it out with one plug and don't have to worry about connecting everything. I'm also thinking about making another male type one to plug it in the house.
In the pics you can see in the background my other creation I'm working on, a pod for my 8" lilliput.
Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
GET PAID TO SURF THE INTERNET
Rundell is offline   Reply With Quote
Old 03-22-2005, 02:41 PM   #2
kmcniece's Avatar
kmcniece is on a distinguished road
I was working on my system last night and was considering a one-ina-all plug for all my things, so I could just pack up my carputer and take it out.
What kind of plug is that?
nice work, by the way, I can't wait to see it tested.
EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
Status:
Installed & Working....
Custom enclosures
Newbie Guide
kmcniece is offline   Reply With Quote
Old 03-22-2005, 03:07 PM   #3
Rundell's Avatar
I got all the parts from DigiKey
40 Pin Connector
Male: H10101-ND
Female: H10102-ND
Pins
Male: H10087-ND
Female: H10091-ND
I found out about this connector from another post with someone makng a docking connector for a lilliput: http://www.mp3car.com/vbulletin/show...lliput+docking
Old 03-22-2005, 03:13 PM   #4
kmcniece's Avatar
I was thinking a master connector for data etc... and a connector for power etc...
My only concern will be the XM antenna. I'm not sure about cutting that apart. So I may just make another connection for that (if possible).
Status:
Custom enclosures
Newbie Guide
Old 03-23-2005, 12:50 PM   #5
wi77iam's Avatar
wi77iam
Hey Rundell, good job by you. I could really use something like this. Exactly how hard was it to make?
wi77iam is offline   Reply With Quote
Old 03-23-2005, 01:02 PM   #6
Rundell's Avatar
Its not hard, just need the right tools and a little bit of time. Since I didn't have a crimper I had to crimp it by hand using needle nose pliers. Also tried very hard not to make a mistake because if I did I may have to end up doing everything on a particular cable all over again because I want everything the same length. If you had the crimper it would be very fast. I probably worked on it for 3-4 hours, just took my time since I didn't want to cross anything and triple checked every connection I made.
Old 03-23-2005, 01:06 PM   #7
Rundell's Avatar
I just remember also that I traced everything and only used the pins on the cable I need. Like for VGA only 7 pins are used by my screen. and Serial was something like 6 pins. So that cut down the work a little bit.
Old 08-18-2008, 07:12 AM   #8
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
kwchan is an unknown quantity at this point
Sorry to dig this up, but I am thinking of making a quick release for my EEE PC.
I want something like a laptop docking station, I have 1 x DC and 2 x USB connections that I want to disconnect quickly.
Are there any quick connect/disconnect ports out there that can handle this?
Something look like this
kwchan is offline   Reply With Quote
Old 08-19-2008, 10:57 PM   #9
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
That is great! What a good idea.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 09-05-2008, 08:39 PM   #10
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Unfortunately, the EeePCs don't come with a dock connector, so we have to cobble something up for them to slip into. I plan on building a single plate that will house the power and USB connections for an EeePC 901; they're on the right side of the unit. If this works as I hope it will, they'll all go into the EeePC at the same time, so it's pretty much like there's a single connection to be made.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 09-05-2008, 09:09 PM   #11
judoGTI's Avatar
Are you worried about shielding at all with the video signal?
'02 GTI
Old 09-07-2008, 05:42 AM   #12
kwchan's Avatar
Any idea where to find such quick release/cradle interface connector?
http://www.hirose-connectors.com/products/EX60B_5.htm
serial port to game port adapter wiring asif General Hardware Discussion 5 08-17-2006 05:47 PM
Macintosh based system Destin MacCar 12 11-24-2004 12:04 AM
Line converter with a Delco Bose system? JGeek Newbie 5 03-27-2004 02:46 AM
Car with no system..How do I wire the speakers to my MP3 system? fogleroller General Hardware Discussion 10 02-14-2002 03:46 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
