wierd, slim dvd -> USB adaper MUST use ps/2 port for power...
I have a slim slot loading DVD Rom drive (working pull from an iMac)
I got an ebay enclosure that takes the drive to USB. the description said "powered off USB port" "no external power needed" etc. yet, it came with an adapter that plugs into your keyboard port "just in case"...
I tried it out. It would ONLY work if I use the ps/2 port adapter to get more power. so I got a 3-headed USB cable (2 ends go to the computer, 1 end goes to the drive ... this lets you pull power from 2 USB ports for more power, get it?)
still no dice. I don't know what gives. each USB port gives 500ma of power right? 2 usb ports would give you 1 amp, and i KNOW this drive doesn't pull over an amp....
how much power does the ps/2 port give? this is stupid, I don't' want to have to run another cable if it's not needed.... just a pet peeve i guess. any ideas?
