The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-22-2005, 10:13 PM   #1
Vehicle: 2002/Acura/RSX-S
My Photos: (0)
Thumbs up Audigy NX 2 review
Well today I grabbed a Sound Blaster Audigy NX 2.
I hooked it up to my Epia 10k (to replace the onboard sound). Installation was a breeze. I immediately noticed a huge sound quality difference. The music was clearer, could go louder and there was MUCH more bass.
I didn't experience any of the other issues mentioned here (strange noises coming from the NX, poping, or lots of CPU usage). The only small issue I've run in to, is Frodo's XM app won't mute the line-in upon exit. I think this has something to do with the Audigy's dual mic/line in port. I'll have to investigate further.
Because I wanted to put the NX behind my LCD, where I had already run a USB cable and installed a USB hub, I spliced a USB cable with the barrel plug connector end of the Audigies power cord. I connected the +5v line on the USB cable to the positive wire, and the Ground line to the negative wire. I was a bit worried that the Audigy would want to pull more current than the USB rail would provide, but this doesn't seem to be an issue.
The audigy comes with some software of varying degrees of usefulness. One nice thing, is the equalizer software. Some of the other features, like bass boost, seem to be realatively useless, as even at very low levels of "bass boost", you can hear distortion. I think this distortion is pre-speaker - that is, it's is somewhere in the amp/soundcard (I suspect sound card).
All in all, I'm VERY pleased so far with my purchase, it has made a big improvement in the overall sound quality in my car.
eleventh is offline   Reply With Quote
Sponsored Links
Old 03-23-2005, 05:58 AM   #2
Vehicle: 2000 Subaru Forester
My Photos: (0)
Don't connect Sound Blaster Audigy NX 2 directly to USB cable power. Use separate power source: for example from PSU, or additional DC-DC converter. And noises will low down.
Check for the last drivers too.
SergeykoR is offline   Reply With Quote
Old 03-23-2005, 05:50 PM   #3
My Photos: (0)
Thanks for the info, but I did not experience noises.
Old 03-23-2005, 08:39 PM   #4
Vehicle: 2003/BMW/M3
My Photos: (0)
Glad to hear that you are not running into any issues... when I had one installed in my car, I had some noise issues (occasional clicking noise), but the killer for me was the cpu usage, which was around 20-30% or so, even in stereo mode, which made .wmv and DVD playing problematic on the 10K.
fatman is offline   Reply With Quote
Old 03-24-2005, 09:22 AM   #5
My Photos: (0)
to eleventh: first time i made connections like you did, and at very high volume (listening rock) in pauses noises was heard.......
Old 03-25-2005, 07:20 AM   #6
My Photos: (0)
Interesting, I'm pretty sure I tested that, but I will double check..
Old 03-26-2005, 01:06 AM   #7
My Photos: (0)
mine runs fine.... ive tested it with an oscilliscope.... no clipping at any volume (no EQ or Boosts on) crystal clear sound always... Check gains on amps.... youre probably clipping the signal...
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
m10000 on-board -> audigy 2 nx -> m10000 on-board fatman Car Audio 7 02-21-2008 11:49 AM
Audigy NX sounds like crap Phythorian General Hardware Discussion 6 03-03-2005 12:39 PM
Audigy 2 NX left channel only issue? help needed... jedi7001 General Hardware Discussion 2 02-28-2005 07:38 PM
Audigy 2 NX full volume after resume STI_FFY Car Audio 4 11-22-2004 09:38 AM
Audigy 2 NX and Sub nick9871 General Hardware Discussion 14 08-18-2004 09:41 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
