Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-29-2005, 03:14 PM   #1
I've got no answer!
Question's Avatar
Way to trick computer into giving itself an ip address?
Is there any way to trick a Win XP computer into giving itself an ip address? I need an ip address so I can VNC into the computer from a palm connected to it. The only thing is, it apparently needs an ip address to go through it.
127.0.0.1 doesn't work, because winxp won't give itself an ip address if it is not connected (says "Media disconnected" on ipconfig). localhost won't work. The computer name (yoda-one) won't work. I tried making a direct connection, still won't work. Tried making it so it will accept incoming connections. Still won't work.
Any ideas? Like a certain ethernet cable wiring that will trick it into thinking it is connected? I've searched google for hours for this.
Thanks.
Question is offline   Reply With Quote
Old 03-29-2005, 03:32 PM   #2
If you want to do a direct connect via ethernet and you don't use a switch, hub router etc.. you have to use a cross over cable.
A crossover cable pinout is:
1 - RC+ 3 - Tx+
2 - RC- 6 - Tx-
3 - Tx+ 1 - RC+
6 - Tx - 2 - RC-
Or you could try to hard code an ip address in the PC and set it to something like 192.168.1.0. You just have to make sure you use the same IP base and subnet on both devices.
These setting should work
PC IP - 192.168.1.1
PC Subnet - 255.255.255.0
Palm IP - 192.168.1.2
Palm Subnet - 255.255.255.0
RJP350Z is offline   Reply With Quote
Old 03-29-2005, 03:41 PM   #3
MySQL Error
jcdillin's Avatar
Just disable the network card, go to add new hardware, select network adapters, select microsoft, then select the microsoft loopback adapter then it wont care if the network cable is connected or not. then you can just set a ip address on it.
but if you need to reconnect the machine to a network you will have to reenable the onboard NIC
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-29-2005, 03:43 PM   #4
HostileJava's Avatar
Is the palm connected through ethernet, wifi, or USB?
Visit my website at:
http://www.hostilejava.com
http://hostilejava.com/gerbil5.jpg
HostileJava is offline   Reply With Quote
Old 03-29-2005, 03:55 PM   #5
I've got no answer!
Question's Avatar
RJP: that's not my problem...I am not actually connected to anything, that's the problem.
jcdillin: cool...I'll try that.
HostileJava: through serial. Search for "PDA remote" to see exactly how I have it setup.
Thanks guys.
Old 03-29-2005, 04:04 PM   #6
Confusion Master
Enforcer's Avatar
this might help
http://support.microsoft.com/?kbid=239924
Enforcer is online now   Reply With Quote
Old 03-29-2005, 04:28 PM   #7
I've got no answer!
Question's Avatar
Sweeeet...thank you jcdillin...I didn't even have to remove the other connection. Just had to add the loopback. Thanks a lot.
The steps in Microsoft's article don't solve the problem, but thanks any way.
Old 03-31-2005, 09:43 PM   #8
MySQL Error
jcdillin's Avatar
awesome, i'm glad it worked for you
肚子笑痛了
S60 Install
Old 04-01-2005, 07:20 AM   #9
Neither darque nor pervert
DarquePervert's Avatar
I'm curious as to why you couldn't simply assign a static IP address in this situation....
I'm glad the loopback setup worked for you, but I'm still wondering...
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-01-2005, 07:34 AM   #10
Confusion Master
Enforcer's Avatar
With W2K and XP if the autosense realises there is not a network cable connected and working it disables the network card. And therefore you cannot assign any kind of IP address. If you follow my previous link you can see how to disable the autosense.
Old 04-01-2005, 08:31 AM   #11
I've got no answer!
Question's Avatar
Yes, but this still weirdly will assign 0.0.0.0, even if you manually assign an ip address. And of course, this is an invalid ip address.
Old 04-01-2005, 10:44 AM   #12
Gotcha. I see.
My Worklog
Making a Car Computer; Need Your Help! Fear Effect Newbie 20 08-18-2008 09:51 AM
Cutting power to USB after computer has shutdown lookinco Power Supplies 61 05-17-2006 01:05 PM
FS: Car Computer Setup - Everything you need!! Pics Galore EBoundEE Classified Archive 2 06-19-2004 09:41 PM
computer theft tracking - PC PhoneHome Question General MP3Car Discussion 9 07-16-2003 02:14 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
