I have an Apacer CP200 COMBO* Do not get the CP200 , get the COMBO.
The diff is the combo has the DVD playable feature and the normal doesn't.
Better yet a reason to get this is becuase you can buy a DC (car) adapter for 29.99. Which translates into not needing an inverter to power it. =) I had a normal external CD burner and had an inverter hardwired in and there was a ton of feedback in the speakers wheni t was turned on. So use this and have an inverterless carputer like mine =)
The cp200 COMBO also has an on off switch on the side if you don't want it on all the time.
It aso can be stand alone (not hooked up to a PC), or USB to a PC as you are desiring. It also has slots on the side for different memory cards to plug directly into. It can also run off a battery (which it comes with).
Good luck!
