Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-06-2005, 03:45 PM   #1
If im having the pc in the boot, how do i get the cables to the dvd drive in the dash
The ide cable and molex will need to be at least 8 feet long, how is this possible?
Or would it be better to put the pc under a chair?
Although the cable still needs to be 4 feet long?
HELP PLEASE
philb is offline   Reply With Quote
Old 04-06-2005, 03:51 PM   #2
I see dead kittens
Quattro's Avatar
Use a IDE -> USB converter and then run a 8 foot usb cable from the back to the drive. For the molex connector use 4 strands of 18 gauge wire to run the power to the drive.
edit: something like this.
http://cgi.ebay.com/ws/eBayISAPI.dll...765747245&rd=1
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 04-06-2005, 03:53 PM   #3
Whats the power supply for?
Old 04-06-2005, 03:54 PM   #4
I see dead kittens
Quattro's Avatar
Thats if your using the drive in your house. Then you would give the power to the drive from the power supply. You really don't need it in the car unless your using an inverter then you could use the power supply instead of running the 8 feet of wire for the molex connector.
Installed
Old 04-06-2005, 08:29 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
There's several people using lengthy IDE cables. Do a search on "IDE cables" or "IDE length" or variations. You'll find posts on running lengthy IDE cables.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 04-07-2005, 12:47 AM   #6
i also recommend getting a IDE to USB adapter. is it a slim drive? then you will need to find one for that. and then just run power from your power supply
mattress is offline   Reply With Quote
Old 04-07-2005, 09:15 AM   #7
Make your own IDE cables...it's quite easy.
TormentInFire is offline   Reply With Quote
usb dvd drive skydiver Hardware Development 2 02-10-2005 09:08 AM
DVD drive missing from hibernation R32 JUhl General Hardware Discussion 6 02-08-2005 03:57 PM
slim dvd and 2.5" hard drive cables warnockm General Hardware Discussion 1 01-03-2005 05:08 PM
Using DVD drive oekundar General Hardware Discussion 1 12-06-2004 06:01 PM
Best remote DVD drive option lookinco General Hardware Discussion 2 08-09-2004 11:28 AM
