There are many ways to use a trigger signal...hacked keyboard, parallel port interface, etc. GIRDER has a number of plugins you can use...just get the hardware.
So you create an event that tells girder to pop up the software that runs your camera (or however you are doing it) whenever it gets the reverse trigger, and closes the camera software when it goes away.
If you are talking about a regular composite output video camera, then just get a circuit to select that video source on your screen when you trigger reverse...
You have a lot of options...you need to decide exactly what you want.
As far as turning the camera on...just put a relay to control the 12v power to the camera, and have your reverse trigger (back up lights?) switch the relay.
