04-23-2005, 11:14 PM
#1
Connect PCMCIA via USB
Is there such device? I found a plenty PCIMCIA cards that give USB ports. And I found PCI cards that can read PCMCIA cards. And PCI, USB and PCMCIA devices that read various memory types: CF, MMC/SD, etc... I'm sure it must be possible, right?
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
04-24-2005, 02:26 AM
#2
Nah, PCMICA is too fast for USB.
04-24-2005, 02:43 AM
#3
And just what crap, pardon my French, is this?
Quote: Originally Posted by http://www.pcmcia.org/faq.htm
What is the throughput of the PC Card interface?
Theoretical maximums are as follows:
CardBus (32 bit burst mode)
* Byte mode: 33 Mbytes/sec
* Word mode: 66 Mbytes/sec
* DWord mode: 132 Mbytes/sec
16-bit Memory Transfers (100 ns Minimum cycle)
* Byte mode: 10 Mbytes/sec
* Word mode: 20 Mbytes/sec
16-bit I/O Transfers (255 ns Minimum cycle)
* Byte mode: 3.92 Mbytes/sec
* Word mode: 7.84 Mbytes/sec
Please note that actual throughput may be substantially less than the theoretical maximums of the interface.
Quote: Originally Posted by http://www.usb.org/faq/ans2#q1
Q1: How fast is USB?
A1: High speed USB products have a design data rate of 480 Mb/s. Full speed USB devices signal at 12Mb/s, while low speed devices use a 1.5Mb/s subchannel.
Q2: How does this compare to other connections used with PCs and workstations?
A2: Here's a quick list of the maximum transfer rates for various connections in megabits (Mb) and megabytes (MB) per second:
serial port: 115kbits/s (.115Mbits/s)
standard parallel port: 115kBYTES/s (.115MBYTES/s)
Original USB: 12Mbits/s (1.5MBYTES/s)
ECP/EPP parallel port: 3MBYTES/s
IDE: 3.3-16.7MBYTES/s
SCSI-1: 5MBYTES/s
SCSI-2 (Fast SCSI, Fast Narrow SCSI): 10MBYTES/s
Fast Wide SCSI (Wide SCSI): 20MBYTES/s
Ultra SCSI (SCSI-3, Fast-20, Ultra Narrow): 20MBYTES/s
UltraIDE: 33MBYTES/s
Wide Ultra SCSI (Fast Wide 20): 40MBYTES/s
Ultra2 SCSI: 40MBYTES/s
IEEE-1394: 100-400Mbits/s (12.5--50MBYTES/s)
Hi-Speed USB: 480Mbits/s
Wide Ultra2 SCSI: 80MBYTES/s
Ultra3 SCSI: 80MBYTES/s
Wide Ultra3 SCSI: 160MBYTES/s
FC-AL Fiber Channel: 100-400MBYTES/s
The fastest connection commonly found on PCs is UltraIDE, which is used for hard drives and CD-ROMs.
Not to mention that full speed is not only extremely hard to achieve, but also there are no devices that require it to work properly.
04-25-2005, 03:40 AM
#4
yes but its hard to find
The one I saw came with a digital cam
- it had a pcmcia card that you could
atach a compactflash to, and the pcmcia
card pluged into the usb pcmcia card reader
I think it was kodak
04-25-2005, 05:28 AM
#5
The Alcatel Speedtouch 120 and Oriniocco silver/gold USB clients (which are the same) are in fact a PCMCIA card in a USB->PCMCIA adaptor.
However, I still haven't tested if other cards work as well, and at which speed.
04-25-2005, 05:36 AM
#6
MySQL Error
There is a thread on this already. I think there may be 1 or 2 solutions found there eventually - i have seen one.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
04-25-2005, 05:37 AM
#7
MySQL Error
one more thing, as the other thread points out (from memory) the adapters that come with PCMCIA wireless cards DO NOT WORK with anything else - only the wireless card they come with.
04-25-2005, 06:48 AM
#8
actually, becuase usb transmits bit at a time its speed in MB as listed for the PCMCIA slot is about 60 MB (@ 480 Mb) which is slower then both thease modes
04-25-2005, 07:21 AM
#9
I did  for "PCMCIA" and "USB" before - got 300+ threads  Now I added "reader" to the mix and found this page. Looks like I'd better pay premium for having exotic PCI device than pay for PCMCIA version and exotic PCMCIA-via-USB adapter. Oh well...
Thanks, folks, you rock!
04-25-2005, 08:14 AM
#10
MySQL Error
you can get a PCI PCMCIA adapter. What is the PCMCIA device you want to use?
04-25-2005, 08:48 AM
#11
I know, check the original post  I can't spare a PCI slot - Asus k8s-mx has only two PCI slots (and 8 USB ports), I already have plans for both. As for device, it's a general question - there are many devices that are common for notebooks and not for desktops, and my mobo is desktop type.
04-25-2005, 12:12 PM
#12
MySQL Error
yeah i saw it afterwards but couldnt be arsed editing.
can you split the lower PCI slot into 2 with a header thingy?
You could use one of these in a USB2 compact flash adapter but it would be messy: http://www.elandigitalsystems.com/ac...ies/cf2pce.php
oh no i've cracked it...here are some companies:
http://www.arstech.com/usbpcmcia.htm
http://www.arstech.com/usb2pcmcia.htm - I think this is what you want. I accept Paypal payments for doing the search, jsut send $100 to....
http://discountcablesusa.com/usb-pcmcia.html - these look like thay have one
04-25-2005, 12:22 PM
#13
Thats pretty cool, I was wondering if there was such an animal as well.
Looks like it is limited to 16bit though, (no Cardbus).
04-25-2005, 12:27 PM
#14
MySQL Error
some people are never satisfied!
04-25-2005, 06:48 PM
#15
I didn't know we where talking about USB 2.0. Last time a researched it we were back in the days of USB 1.1.
| Thread Tools |
| Display Modes |
Linear Mode
