my bad.... okay lemme try and explain it again...
i'm using a panasonic slot-load slim line cdrw/dvd with a centrix slim line to USB adaptor.
right now... i've got a 5v (red) and ground (blk) extended to the dvd drive. On the end of these extended wires is a barrel plug that plugs into the back of the centrix adaptor for power. (possible cause #1 could be this because no where in the adaptor or instructions does it mention what size barrel plug needs to be used... i just guessed it and put the plug in and it stays in). Another reason why i suspect this is because the LED indicator on the DVD drive doesn't light up at all.
for the actual USB... i'm using a 3' extension that originally was plugged into a built in USB port on the mobo. It worked fine like this for the time I had it connected here. Recognized it all the time and played CD's and everything.
Then i bought some USB connectors to make use of the USB3/4 ports on my mobo (possible cause #2 i might not have plugged the 5v, data, data, ground correctly in the mobo). When plugged into any of these.... it recognizeds it only when i disconnect and reconnect... and it won't play ANYTHING
Now... i tried plugging the DVD back into a built-in port (where i originally plugged it) and it works fine again.
