Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-28-2005, 05:47 PM   #1
djXternal's Avatar
djXternal is on a distinguished road
Dual Sound Cards
Ok guys i want to have dual sound outputs for my carpc....
i have one output in an on-board soundcard on my EpoX 8RGM3I...
the second sound card i just received from a guy one ebay, nuthin real special but its a 5.1 surround card which is what i wanted... its a C-Media 8738 6 Channel PCI Sound Card...
ok everything was great till i tried to install the sound card... when i try to install using the provided installer from the factory, it wont even let me attempt it because for some reason XP didnt detect the card, but if i do finally get XP to see the card, i try to install using the XP "Found New Hardware Wizard" i point it to the xp drivers on the provided cd, and it tries to install
everything looks like its installing fine until it gets to what seems to be the last file that needs copied "cmuninst.dat" and the computer doesnt freeze but the installer doesnt seem to continue just sits there and says its still copying cmuninst.dat
any ideas?
Debating on installing a carpc in my Jeep.....
djXternal is offline   Reply With Quote
Old 04-28-2005, 06:01 PM   #2
Tainted Love
Cris's Avatar
Cris is on a distinguished road
As far as I knew you coudn't have 2 sound cards on a pc, but that;s just what I know...
Cris is offline   Reply With Quote
Old 04-28-2005, 06:03 PM   #3
djXternal's Avatar
i was told by some others on here that it was possible
Old 04-28-2005, 06:06 PM   #4
KyleYankan's Avatar
KyleYankan is on a distinguished road
I had dual sound cards on an old PC once. Installed like butter though. Are you sure the CD is good? Try installing drivers off the cd onto the HD then isntaleld the soundcard from there?
KyleYankan is offline   Reply With Quote
Old 04-28-2005, 06:14 PM   #5
Vchat20's Avatar
Vchat20 is on a distinguished road
yes you can have 2 sound cards. i do here myself since the onboard card doesnt have a gameport. but to make use of both, the programs you wish to use have to have the ability to tell it what sound card you want it to use. i know winamp and windows media player can do this.
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 04-28-2005, 06:17 PM   #6
djXternal's Avatar
yes i only need one of my front ends to use the onboard sound, and the rest to use my new soundcard... but that shouldnt be a problem... my problem is the installation of the drivers
Old 04-28-2005, 06:20 PM   #7
Vchat20's Avatar
did you try the drivers from here: http://www.cmedia.com.tw/download/OS...738_WDM_OS.htm ?
Old 04-28-2005, 06:32 PM   #8
djXternal's Avatar
ill try those now... and wow thats got to be the slowest server ive ever seen... it took me almost 5 minutes to d/l a 2.44MB file when im on Fios
Old 04-28-2005, 06:40 PM   #9
djXternal's Avatar
ok i tried the new drivers and the setup program runs, but does the same thing as the old setup program, says "Waiting for sudio driver to be ready" and had little dots accumulating underneath it for a very long time...
any other ideas?
Old 04-28-2005, 07:14 PM   #10
lastberserker's Avatar
lastberserker is on a distinguished road
Note that on many mobos onboard sound and video do not live well with plug-in cards.
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
lastberserker is offline   Reply With Quote
Old 04-28-2005, 07:51 PM   #11
djXternal's Avatar
do u actually have to have a sound blaster sound card in your pc in order to install its drivers? because if not i could try and download there drivers and install them, if that works then doesnt it mean that the problem is with the drivers for this card?
Old 04-28-2005, 08:22 PM   #12
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
OMG of course you can have mulitple sound cards.
this has been discussed before. (search!!!!)
However i would suspect that onboard audio will not work well PCI so USB would be a good option.
USB soundcards are designed to eb used with existing soundcards and not cause problems. You may be able to use a couple of PCI cards but as I say i dont knwo about the onboard. I suggest you search for the other threads.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-28-2005, 08:25 PM   #13
djXternal's Avatar
well i would go usb if i had the money, the pci was a much cheaper way to go, i may have to ditch this cheap sound card and try out a sound blaster live 5.1 card and see if that works.
oh btw, does anyone know exactly what inputs/outputs the sb live 5.1 card has?
Old 04-28-2005, 08:42 PM   #14
MySQL Error
I bet the soundblaster site does
Old 04-28-2005, 08:49 PM   #15
opps's Avatar
opps is on a distinguished road
Dual sound cards if not work mostly cause the system conflict, here are some suggestions you should try :
1. Plug out the PCI sound card before install onboard one and make it work first.
2. Change onboard sound IRQ and Address like IRQ 11 and 240.
3. Make sure your on-board work well with new setting then plug the PCI sound back into machine and start the PCI sound card installation.
4. If still have problem try to move your sound card to other PCI slot or force
the PCI slot to use IRQ it can be set in your bios setup.
Also not all sound cards can working when dual but mostly cause the conflict so try more other setting may get it work.
opps is offline   Reply With Quote
Dual Sound Cards? HummDinger Hardware Development 10 04-11-2007 06:53 PM
Two Instances of FP and two sound cards djXternal FrodoPlayer 7 04-13-2005 12:58 PM
Dual Sound Outputs (No HU) djXternal Car Audio 8 03-04-2005 04:15 PM
Sound cards from incarpcs , sacrificing sound quality? skinhead General Hardware Discussion 15 09-02-2004 03:05 AM
PCMCIA Sound Cards? Bodgy General Hardware Discussion 2 07-05-2004 08:12 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
