The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 05-09-2005, 12:25 AM   #1
Vehicle: 1997 Mitsubishi Eclipse RS-T
My Photos: (0)
I fit an opus 90w in Morex case, Pix and a few tech Q's for safety
thru some modifying, i managed to fit an Opus 90w PCB into the morex 3677 case. A few questions/concerns about doing this:
the first 2 pictures are how i would like to have the board oriented since the power wires would exit that side thru the back of the case, but as you can see the USB connection is very close to the yellow thing. (sorry, don't know what thats called).
-What is that yellow thing?
-does it get hot?
-is it okay to have the USB plug hitting it?
-is bending the pins upward a bit an option? just enough to clear the yellow thing.
the next two pics are with the board turned 180* the other way.
the fit is better as far as the USB connection goes, BUT:
-does the black version of the yellow thing get hot?
-Would there be any type of interfearance with either the yellow or black thing and the USB plug wires/signal?
the last pic is of the PCB sitting on a foam pad for next to the Via MB. its a very snug fit, but a nice fit. i will probably use 2 way tape for the pad to case, and some other option yet determnined for the PCB to pad. any ideas for that?
Tim97rs is offline   Reply With Quote
Sponsored Links
Old 05-09-2005, 02:56 AM   #2
Registered User
aoLhaTer's Avatar
Vehicle: 04 Infiniti G35 Coupe
My Photos: (0)
Bend the usb pins all you want
Break them off if you really want
If youre not using them it doesnt matter; its not like theyre connected to anything
Go for it
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 05-09-2005, 07:45 AM   #3
jimothy's Avatar
Vehicle: 2003 BMW 325i
My Photos: (0)
cool, now if you could only get my 150w in a morex....
jimothy is offline   Reply With Quote
Old 05-09-2005, 08:47 AM   #4
My Photos: (0)
Go for it
actualy they are in use, or they will be. i just didn't have the room to plug in the plug from the MB.
Old 05-09-2005, 08:50 AM   #5
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
The "yellow thing" is basiclly the only thing in the PSU that gets a little hot. From what I can see in your first pic, you could place a couple of spacers underneathe the small PCB ths mounting in an upper position so that the PSU won't touch it.
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 05-09-2005, 08:56 AM   #6
Curly_cat's Avatar
Vehicle: Audi A4 2.4 V6 and 1972 MGB Roadster
My Photos: (0)
Why would you need to?
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
Curly_cat is offline   Reply With Quote
Old 05-09-2005, 08:58 AM   #7
jimothy's Avatar
My Photos: (0)
well I'm just not sure how to get the wires from the Opus into the case w/o cutting holes (motherboard power, HD power and on\off)... but i'll probably just end up cutting holes.
Old 05-09-2005, 09:06 AM   #8
Curly_cat's Avatar
My Photos: (0)
Well, either go for a bigger case, so that you can fit the 150 inside it, or don't bother with a case at all.
Old 05-10-2005, 12:36 AM   #9
My Photos: (0)
any other input...?
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
