The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 05-11-2005, 05:49 AM   #1
Juliemac's Avatar
Vehicle: '81 MKI Scirocco w 2L 16v
My Photos: (0)
System Cooling
Since the system is going in the trunk of my car, I started to think of ducting air.
What are some of the bright and (not so bright) ideas you guys have come up with?
TIA
Julie
Juliemac is offline   Reply With Quote
Sponsored Links
Old 05-11-2005, 07:23 AM   #2
My Photos: (0)
if you are using a regular case try something like the pic below. The fans are red. placing them like that will have better flow inside the case and throw out the hot air more easily.
a bit more info on your setup though will help finding the brightest idea :]
petros
peterh is offline   Reply With Quote
Old 05-12-2005, 05:28 AM   #3
Juliemac's Avatar
My Photos: (0)
Actually, I am using a Shuttle case with the heat tubes and radiator with one extra fan on the front panel to cool the case and supply.
I was wondering if the trunk needs to be ventilated at all. It would be a great heat trap in the summer.
Shuttle FX41G, Modded MK4.5 PSU w microcontroller, 500Mb Ram, 40 Gb HD, 8" LCD w Touch screen, WLAN.
5" LCD for IR and reverce cameras.
Http://www.menloparkrandd.com/scirocco
Old 05-12-2005, 07:25 PM   #4
Vehicle: Saab Aero 2000
My Photos: (0)
I have my carputer in the glove box. The neat part is that my Saab 9-5 has cold A/C air in there. Only problem is when engine is off... gets quite hot in that small space.
Gredd is offline   Reply With Quote
Old 05-12-2005, 07:43 PM   #5
lastberserker's Avatar
Vehicle: Honda Odyssey EX 2000
My Photos: (0)
Buy a few heatpipes and transfer the heat to the car's underside. How about that?
Oh, and if you find a shop that sells bulk heatpipes, please, post it here
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
lastberserker is offline   Reply With Quote
Old 05-12-2005, 08:07 PM   #6
Vchat20's Avatar
Vehicle: '96 Ford Windstar
My Photos: (0)
watercooling routed outside the car. check my previous threads/posts.
Ford Windstar XP (last update: 06/25/05)
Current Progress:
[▓▓▓▓----------------]20%
Planning Near Completed. Some Parts Bought/Salvaged
Vchat20 is offline   Reply With Quote
Old 05-12-2005, 08:13 PM   #7
PatO's Avatar
Vehicle: 2001 Jeep Cherokee
My Photos: (0)
Your car already has a massive radiator to cool the engine. If it's good enough for the engine, it must be good enough for a piddly little CPU... Get some liquid coolers for your cpu and vid card and hook 'em up to the car!
Edit: Bounus - don't even need to spend the bucks on a fluid pump - the car already has one!
http://jeepmp3.home.comcast.net
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 05-12-2005, 09:05 PM   #8
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
WRONG!
The radiator in a car cools the engine coolant to a temperature that's sufficient to cool the engine. You're talking about 150-180 Farenheight.
That's WAY too hot for a CPU to operate.
Now if you're giving this advice to a n00b to see them fry CPUs repeatedly, that's one thing...
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
New EWF + MinLogon and CF instructions SFiorito WinNT Based 252 05-28-2008 02:22 PM
Who's made some type of cooling system? falconey Fabrication 5 05-11-2004 01:49 PM
FS: Carputer system w/o monitor Toups Classified Archive 7 04-21-2004 12:43 PM
FS: Carputer system w/o monitor (Boots in 15 sec) Toups Classified Archive 0 04-01-2004 11:01 AM
linux system owners with web site please post Jake General MP3Car Discussion 13 10-23-2002 08:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
