06-06-2005, 03:30 PM
#1
Vehicle: 1999 Honda Accord Cpe
My carputer won't turn on (MB or power supply??)
Hi. I currently use a Book PC 500 mhz i810 for my setup.
I'm trying to determine whether I fried the power supply or the motherboard. Anyone know a quick way of finding out.
I turned my carputer on the other day, drove to the gas station, turned it off. When I hit power, it would no longer have any response, no fans,nothing.
I would try swapping the power supply, but I don't have a spare micro atx power supply.
Thanks for any suggestions.
06-06-2005, 03:33 PM
#2
Tainted Love
Vehicle: 2007 Renault Megane
Then you won't know, will you.
Test it with an ATX PSU, and see.
You could also try with a multimetre, and see if power comes out of the PSU.
06-06-2005, 03:38 PM
#3
Vehicle: 2003 Ford Expedition
If absolutely nothing comes on, fans, LEDs, etc, I'd guess it's the power supply. If you hook up a power supply to a bare motherboard, even without a CPU, the power supply fan will at least spin. Might crack open the power supply and see if there is a fuse in there. A multimeter in the power supply will tell you if it's failing or not as well....Just dont short any leads and let the smoke out!
cent
06-06-2005, 04:08 PM
#4
So atx power supplies have the same outputs.
Good idea with the multimeter, i'll try that as well when i get home tonight.
Also, on a side note, i posted in for sale forum, but dows anyone have an extra micro-atx power supply they want to sell or trade (or give me)? Or does anyone know where to get one for really cheap? Thanks all.
06-06-2005, 04:10 PM
#5
Tainted Love
ATX is the standard, in terms of connectors and the wires that go into it, not its size.
06-06-2005, 04:20 PM
#6
MySQL Error
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
- Pull Drives power connector out and the main ATX power connector out.
- Short pin 13 and 14 on the ATX connector to see if the PSU turn on.
- If not, the PSU is likely going SOUTH.
- If it turn on, the problem could be somewhere on the mobo. Make sure to check the output voltage on all rail to see if the PSU out put within Spec (10% I think).
06-06-2005, 04:23 PM
#7
pardon my ignorance.. but how do u short a pin??
06-06-2005, 06:05 PM
#8
Tainted Love
pardon my ignorance.. but how do u short a bin??
Connect them!
06-07-2005, 08:33 AM
#9
MySQL Error
Use metal paper clip and connect the 2 together. Just make sure that "paper clip" doesn't touch the mobo or any sensitive parts.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
