Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-22-2000, 04:15 PM   #1
dizzzyduck
Post how do you remember to turn off the inverter?
before you get out of your car, how do you remember to turn off the inverter? do you guys have a light installed? or perhaps a beeping noise? I want to do something to remind me to turn it off. Is is possible to make something to make a beeping noise if the inverter is on but the car keys are out of the ignition? or something like that?
thanx
dizzzyduck is offline   Reply With Quote
Advertisement Sponsored links
Old 07-22-2000, 04:55 PM   #2
Phacade GSX
Post
The best thing to do is to wire the inverter using a relay, such that the power to it is controlled via the ignition accessories switch. That way, whenever you turn the key off, the inverter turns off.
Marlin
Phacade GSX is offline   Reply With Quote
Old 07-22-2000, 11:01 PM   #3
Kevin
Post
I don't agree with Merlin. I think the inverter should still run when you turn off the ignition so you don't have to reboot every time you stop at 7-11 to get a Coke. Most of the time you will remember to turn the inverter off when necessary. My 'puter can run for about 8 hours before the battery dies, so if I'm only stopping for an hour or two I often leave it on. I have left it on overnight a couple of times, though, and the battery has died. So I bought and installed a "Priority Start" (see previous posts) which turns it off automatically if the battery voltage gets too low.
Kevin is offline   Reply With Quote
Old 07-22-2000, 11:45 PM   #4
Probedude_2000
Post
I make an autoshutdown unit. Also serves to start up your ATX motherboard when your ACC line comes on. Details at http://www.dschmidt.com/autooff.html
Probedude_2000 is offline   Reply With Quote
relay, inverter, fuse problems cheesyhoward Power Supplies 5 06-02-2005 10:04 AM
Help with inverter Starkan General Hardware Discussion 5 07-10-2004 07:43 PM
relay, inverter, fuse problems cheesyhoward General Hardware Discussion 6 06-22-2004 04:05 PM
Navigator - Turn By Turn for Victoria(Aus) Trial (I got it) Nokia6600 GPS 4 03-25-2004 06:53 AM
odd inverter behavior jshrieve General Hardware Discussion 30 04-10-2001 05:53 AM
