Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-16-2005, 12:13 AM   #1
pastypyro's Avatar
USB Powered External Drives
Does anyone know of any large (250 GB+) drives that are external and powered over the USB bus? All the large drives I've seen would require either an external power supply or connection to a PCs power supply, and I don't want to hack apart my laptop to rig something up.
I was looking for something I could run in the car, on my laptop, and on my desktop to carry all my stuff around and take it home and have it available on the network in the evenings.
Any suggestions?
pastypyro is offline   Reply With Quote
Old 06-16-2005, 03:21 PM   #2
pastypyro's Avatar
Bump... is it even possible to power a 3.5" drive over USB?
Old 06-16-2005, 03:34 PM   #3
White 350z's Avatar
I haven't seen any... HDs probably require more power than the USB bus can provide.
CarPC Status
[|---------] 10% Complete
Home Rig -
Athlon 64 (939) 3200+ (Watercooled)
DFI NF4 SLI-D Mobo
Gigabyte 6600 128MB PCI-E Video Card
(4) 9GB U160 SCSI HDDs in 36GB Raid 0 Array
160GB Seagate S-ATA Drive w/NCQ
Dell 20.1" Widescreen LCD
White 350z is offline   Reply With Quote
Old 06-16-2005, 03:40 PM   #4
MySQL Error
Sonicxtacy02's Avatar
not possible. The usb bus doesnt have enough power to drive the HD components.
Old 06-16-2005, 03:47 PM   #5
MySQL Error
Scouse Monkey's Avatar
USB is 5V, 3.5" hdd needs 12V. So you would need a step up.
USB can supply 500mA, 3.5" needs about 15-20W
Even laptop usb enclosures sometimes need yo use the power from a second usb port so even if you had a 5-->12V step up you would need the power of 6-8 USB ports. Not gonna happen!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 06-16-2005, 03:48 PM   #6
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
USB provides only 5volts. No way to power a 3.5 HD with out external power because they require a 12 volts.
Sorry.
Michael
Wiredwrx is offline   Reply With Quote
Old 06-16-2005, 03:49 PM   #7
Para Laura
thanatos106's Avatar
No possible because the USB bus does not provide 12v that a large HD(3.5") need to work.
In the other hand if you wat to set for a 100GB (2.5") usb they have it in the market but is pricy.
thanatos.
thanatos106 is offline   Reply With Quote
Old 06-16-2005, 03:51 PM   #8
Neither darque nor pervert
DarquePervert's Avatar
You might consider an MP3 player that has a battery pack that operates as a USB drive. This is how my Archose Gmni 100 works. It's only 20GB, but there are mods to use a larger drive. I think you can get 100GB drives working in it. It's a standalone MP3 player, as well as a USB 2.0 HDD.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 06-16-2005, 04:01 PM   #9
MySQL Error
yeah i was thinking about using an ipod as my music drive.
Old 06-16-2005, 05:02 PM   #10
pastypyro's Avatar
I'll work something else out then. I thought that 3.5" drives only ran on 5 volts but may have drawn more current. Thanks for the replies.
Old 06-16-2005, 05:07 PM   #11
jbors's Avatar
Yeah, the biggest capacity you can have with USB powered HDD is about 80 or 100. Mine is 60 (G-Tech) and works pretty good on EPIA-M. My laptop does not accept it though...
[edit]I'm wrong. The biggest I've seen so far is 160GB bus powered http://www.newegg.com/Product/Produc...2E16822154707R[/edit]
Car2PC adapter. Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
Old 06-16-2005, 05:12 PM   #12
The only thing i know is that it IS poosibly....
A friend of mine got a 12GB usb hdd, its a 2,5" in a enclosure, he got an IBM laptop, and can power it from one USB port, but on my laptop (ECS) it need two USB cabels....
AI also got a 20Gb medion MP3 jukebox, it has no problem starting up when connected USB
Palcom is offline   Reply With Quote
Old 06-16-2005, 05:17 PM   #13
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
2.5, or what is sometimes called a laptp drive, run on 5 volts alone.
I don't think that you can power a laptop drive off of the USB, but you might be able to. You could always get a 5 volt regulator and power the drive from the cars 12 volt supply. I did a little research, and the newer, faster, bigger 2.5 HD use about an amp during start up, and less once fully spinning. You can use an LM7805 or equivalent voltage regulator (You can get them at radio shack for under 2 dollars). It supplies 1A continuous. It should be fine for your application, although I wouldn't run more then 1 Hard Drive off it. They are pretty simple to use and connect, and need no external components.
Post here if you need some help.
Michael
Old 06-16-2005, 05:47 PM   #14
MySQL Error
Michael
I have a 20gb IBM laptop drive in a USB enclosure that runs fine off a single USB port - even on my laptop.
Old 06-16-2005, 05:55 PM   #15
Chairboy's Avatar
I have a 200GB drive in my car, external connected via USB. I wired a power wire to a molex and connected it to my Opus and ran it to the drive. I just plug in USB and the power cable, and it powers up automatically when the computer does, including from Hibernation.
No problems, and it makes it super easy to move big chunks of media back and forth.
Chrysler 300 - Fabricating
http://hallert.net/
Chairboy is offline   Reply With Quote
Looking for a creative solution: USB bus still powered after CPU is off S4Per Power Supplies 197 06-15-2006 08:47 PM
Converted 3.5" HD to External USB PaCMaYNE General Hardware Discussion 12 01-09-2005 04:55 PM
HOT!! Hammer 250gb External USB Drive for $39.99 AR YMMV integramodder General Hardware Discussion 3 12-31-2004 03:36 PM
Need help with External USB Laptop HD VWTronics General Hardware Discussion 1 05-26-2004 12:58 PM
Storix External USB 2.0 DVD Review VWTronics Input Devices 8 09-27-2003 06:20 PM
