Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-16-2005, 11:40 AM   #1
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
Quick disconnect Box via cat5's
I was thingking of making a quick disconnect box for running all my wires
(kind of a snake box i would call it) where there were 2 project boxes on either end x amount of calbe between the boxes and ide ps2 db9 usb and other connectors including vga and hopefully the xenarc 20 pin adapter pin on both sides of this "snake"
this way when working on my car i can have a quick disconnect of the wires and possibly run alot less spagetti (not the forum member) from the front to rear of the vehicle by wire tying say 20 cat 5 cables together and having access points on both sides with room for expansion. Alomost how telephone jacks are a bunch of extra wires there waiing to add new lines just tap in and go.
aside from amp draws on the gague of wires and alot of money possibly spent on connectors anyone know of similar projects or see any potential problems with this
if a can snake one large wire and have all my connections done i think this is a BIG advantage
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 06-16-2005, 11:51 AM   #2
evandude's Avatar
evandude is on a distinguished road
run any power lines separately, and use the cat5 for signal lines...
you also have to worry about signal quality... for instance, USB cables are shielded, and if you go running them through 8-conductor cat5 alongside other signals, things might not behave very well.
and... have fun making all the wiring harnesses to go from regular cables to cat5 and back... I've gotten quite sick of making similar ones (on a much smaller scale)... in the time it takes to make all the adapters you could have easily just run separate wires...
personally I think just disconnecting all the cables from the computer is easier anyway, and at least in my car, I can run a new wire pretty easily, so I don't consider it a big problem. but it all depends on the car, and personal preference...
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 06-16-2005, 11:57 AM   #3
FociMan's Avatar
FociMan is on a distinguished road
I think it would work for a lot of the wiring required in a car install. But as you rightly point out the current carrying capacity of these cables is going to be very low. It should handle VGA, USB etc.
FociMan
Ford Focus Collection
EPIA M10K / 512Kb / Creative Audigy NX USB
8" touchscreen
D-Link USB Radio
USB GPS Mouse
Bluetooth GPRS Web Connection
Centrafuse Beta2 / MapMonkey
FociMan is offline   Reply With Quote
Old 06-16-2005, 11:57 AM   #4
Rickertsen2 is on a distinguished road
this really isn't a wonderful solution. Many things use differential signaling and need to be on the same pair, require sheilding etc. If you do choose to do this, then why not just run one big cable? It seems to defeat the purpose if you are running may cables.
Rickertsen2 is offline   Reply With Quote
Old 06-16-2005, 12:38 PM   #5
Raw Wave
thanks for the feedback i suppose ill scrap that idea and run some more wires
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 06-16-2005, 01:42 PM   #6
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Build a dock. Then you can use all of the real cables.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is online now   Reply With Quote
Old 06-17-2005, 04:34 AM   #7
84RegalRider's Avatar
84RegalRider is on a distinguished road
printer cable 25 conductors. very clean, making a 10 switch box with it.
84RegalRider is offline   Reply With Quote
Old 06-17-2005, 11:33 PM   #8
SnyperBob's Avatar
SnyperBob is on a distinguished road
I basically use the cat5 just like you say in my car for low voltage things. Like 5 volts or less. I use one cat5 for the power on button and the power LED and reset buttons. You can combine all three into one cat5 cable and run them to where you want them.
I use the quick connects from Radio Shack, that are typically used for remote control car battery packs. They are very durable, large enough to actually use, and hold up to extended use. You can see a picture of it in the photo album for my car.
You can see it at www.mobile-effects.com
Go to the Photo Gallery->Mobile-Effects Installs/Projects->Aspire Install-2003
It's picture number 73 on page 9 in that directory. I spliced into the wires in the case, then ran pigtails out of the back. I just disconnect them easily when I need to remove the machine.
Free file hosting, picture gallery hosting for installs, PM me.
Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
SnyperBob is offline   Reply With Quote
Old 06-17-2005, 11:47 PM   #9
SnyperBob's Avatar
Just added some more pics of the wire splicing I did. Same album, last page.
Box Loudness.... Help? Harlanc03 Car Audio 13 06-08-2005 11:10 PM
quick system disconnect idea d_sellers1 General Hardware Discussion 7 05-14-2005 11:35 AM
Wiring Distribution Fuse Box, cable length etc Pabs General Hardware Discussion 0 09-06-2004 05:59 PM
Case design for a stowage box. nibix Fabrication 3 07-10-2004 06:12 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
