Quote: Originally Posted by ^tyrant^
i updated my EPIA M to the newest driver today, and it flashed fine said press F1 to reboot i did that, the system restarted and never posted, no video nothing.
anyone have any ideas?
ive done cleared the cmos.
Ya,
Do you have a backup of the original. Was his an on board flash, or did you remove the bios and flash it. Try putting the original back in. It will prove if you hosed the bios chip. You can always try and Reflash back to the new flash if that works. Perhaps you had a problem during the flash process that can be corrected with a reflash.
You probably didn't hose the BIOS, it is not that easy to totally kill a BIOS. BIOS updates are pretty tricky. They change the settings, so the settings can be the issue. How to get to the settings once you have flashed can be a big problem.
Try removing all non essential hardware from the system. Get rid of any extra HD's, CD Roms and DVD drives, Extra PCI and ISA cards (Assuming you have any ISA). Try booting with a VERY Basic system. Perhaps you will be able to gain access to the BIOS to make the appropriate changes.
Good luck.
Michael
