Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
Hi all,
Ok, now I have decided to buy CNX-P1900 Dual Output 140 Watt 12V DC-DC Regulator instead of OPUS 150W PSU, which only provide 10W more power than CNX for more than $50.
What I want CNX PSU to do for me is to provide those power on/off/standby/hibernate functions as OPUS PSU does. Below is an excerpt from OPUS 150W PSU and that is exacly what I want from my CNX PSU.
Back to Idle state:
When the ignition switch is turned off, The DC-DC power supply will delay going into shut down, stand-by or hibernate modes.
The delay time is set by a set of jumpers located in side the DC-DC power supply control board (Refer to the heading ‘Setting the turn off delay’). Once the delay time has elapsed, the DC-DC power supply hand shakes and controls with the motherboard to go into one of three states namely shut down, standby or hibernate mode.
If the ignition is turned on again, while shut down delay is in progress, the DC-DC power supply will turn off the delay function and the PC will continue operate normally.
If the PC is manually put into stand-by mode, taping the keyboard or pointing device will start the PC as long as Ignition is on.
If the PC is manually put into power down mode, to restart the PC the ignition must be turned off wait 5 sec and turned on again.
Anyone or owner of CNX 140W PSU knows whether CNX PSU support above functions? It would be nice if it does.... I would appreciate answers from you guys.
Regards,
Joon
