Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-12-2001, 04:29 PM   #1
Unregistered User
ODYSSEY's Avatar
ODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant futureODYSSEY has a brilliant future
Question hardware volume control
How would I go about making a hardware volume control? I'm using a SB Live and all four channels. Before the sound get inputed to the amp I need a hardware volume control. I want to make one knob controling all four channels volume. Is there a POT that contols for items? How do I use the POT, ie which wire goes where? What type of POT do I need. I want to be able to mount the knob in-dash or console. Any suggestion?
ODYSSEY
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Advertisement Sponsored links
Old 03-12-2001, 06:04 PM   #2
Live and Kickin'
Arby's Avatar
Arby is on a distinguished road
Post
There is a small, 5 pin header on the sblive that you can hook up momentary switches to to control the volume. Lemme go find some more info.
http://mp3box.2y.net
www.arbybean.com
Arby is offline   Reply With Quote
Old 03-12-2001, 06:36 PM   #3
Live and Kickin'
Arby's Avatar
Post
I'm planning on doing this for my next project, so I dug up a little more info. I took a couple of pictures of my SBLive:
http://mp3box.2y.net/temp/livevol1.jpg
http://mp3box.2y.net/temp/livevol2.jpg
I belive a switch between the top and the bottom would be volume up, and a switch between the middle and bottom would be volume down.
Hope this helps you.
www.arbybean.com
Old 03-12-2001, 08:01 PM   #4
Unregistered User
ODYSSEY's Avatar
Post
That is a good idea. But what if your system/sound card happens to lock-up? I want something that not depentant on the computer. Any suggestions?
ODYSSEY
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 03-12-2001, 08:29 PM   #5
Kain101
Post
use a poteniometer (it is basically a variable resistor)... wire it so that it has an input and output and u can just connect it between your existing wires with out cutting them
Kain101 is offline   Reply With Quote
Old 03-12-2001, 10:04 PM   #6
TheDingo
Post
I just have volume control built in to hot keys on my touchpad...
TheDingo is offline   Reply With Quote
Old 03-12-2001, 11:36 PM   #7
Unregistered User
ODYSSEY's Avatar
Post
Any type of poteniometer? Do I need 1K, 10K?I was thinking about using 4 like the one below. Then just stacking the four on top of each other and put a rod in the hole.
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 03-12-2001, 11:55 PM   #8
Caviar
Post
chek out Tehota's thread...... he has added volume switches to his Passat.
Caviar is offline   Reply With Quote
Old 03-13-2001, 12:52 AM   #9
Kain101
Post
go with the 10k... and i like the stacking idea
Old 03-13-2001, 02:53 PM   #10
Mp3_Truck
Post
im staying away from the soundblaster live and going with a hercules 5.1 with upfront bay contols and rear rca ouputs, i beleive they make a model with hardware volume built into the bay, i just have to see if it controls the front bay outputs or the rca rear outputs.
<p align="center"><a href="http://www.mobilemediacentral.com"><img border="0" src="http://www.mobilemediacentral.com/images/logos/mmclogo.jpg" width="171" height="151"></a></p>
Mp3_Truck is offline   Reply With Quote
Old 03-19-2001, 06:39 PM   #11
Unregistered User
ODYSSEY's Avatar
Post
ok, I got my pots. Stupid question. How do I use it? I have three connectors? I know one is input, output, then ?. Sorry I don't know too much about elec.
ODYSSEY
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 03-20-2001, 03:58 AM   #12
Bj
Bj
Post
wire it like this
(o) front view (cool ascii view hey)
123
pin 1 is ground
pin 2 is output
pin 3 is input
so for the left channel......
the active wire from the sound card, goes onto the 3rd pin, your amplifer input hooks up to pin 2. The shield from both amp and sound card, go to the ground pin, but unless you've done this before, it may be a tad hard to understand.
why? because 10k impedance had to match your soundcard output and your amplifier input.
If you have them unbalanced, you may experience noise from the amp when you have the pot in the halfway position.......then you will have to build a matching resistor network.......
But in most cases just wire it up and it should work
Enjoy
[This message has been edited by Bj (edited 03-20-2001).]
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
Bj is offline   Reply With Quote
Old 04-09-2001, 01:57 PM   #13
Dtrixter
Cool
The potentiometer stacking is a good idea... one word of caution though, the pot that you have choosen is not a "heavy-duty" type. It will wear out fairly quickly used frequently. It will also be rather delicate and need to be handled carefully.
Dtrixter is offline   Reply With Quote
Old 04-09-2001, 04:21 PM   #14
Retired Admin
Aaron Cake's Avatar
Aaron Cake is on a distinguished road
Talking
BJ explained it perfectly, but there is one thing to add:
Be sure to get a high quality sealed pot. Normal pots are very cheap and wear out quickly with any sort of use. Also, sealed designes keep the horrible dust found in cars out. When I clean out my player, the rag comes out pitch black from all the greasy dust that is formed. Terrible stuff. Normal pots will last a few months then become crackly.
You will pay more for a sealed pot (probably close to $8 a piece) but it is worth it. Multiturn is not necessary.
Aaron Cake is offline   Reply With Quote
Old 04-11-2001, 07:02 PM   #15
jjohnson
Post
A company called Xicor ( http://www.xicor.com ) makes some really neat little digital pots. They are basically a small DIP package with no external components needed.
You hook 3 pins up just like a normal pot, and then connect 2 momentary switches (or a rotary pulse switch if you want an "analog" feel to it) to the digital Up/Down inputs. It works exactly like a digital car stereo with up and down volume buttons. If you hold down a button it will accelerate to zero or full volume.
They have several models with different resistance values and the IC's even have onboard nonvolatile flash memory to store the volume level even when power is removed! They offer linear and logarithmic versions (for audio).
For a stereo signal you could gang two together so they step in unison. There's even a mute input you could connect to a small switch.
I have a couple of these I was going to mess with but never got around to it. I'll be sure to post some info if I ever use them.
Jason Johnson
Yorba Linda, California
http://www.m2pc.com
M²PC Phase IV - *** PENDING ***
jjohnson is offline   Reply With Quote
smaller than that powermate usb volume control dim-8 Input Devices 6 08-21-2007 09:07 AM
control volume turbochris General Hardware Discussion 24 06-09-2004 06:57 AM
Volume control failed! djmole Media Engine 2 03-04-2004 02:02 PM
Soundblaster Hardware volume control Mitokondria General Hardware Discussion 2 05-01-2003 10:21 PM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
