Quote: Originally Posted by Cypher333
also whats wierd is that "my computer" shows the older drive as 2 drives even though it is one. it has always been like this though
yeah, those are called "partitions"
if you set one drive on cable select, you should set the other one on cable select also. However, it's more reliable to just set one to master and one to slave and not mess with cable select at all... but in any case, mixing master/slave and cable select on the two drives is not a good idea.
then again, if control panel is picking them both up then it sounds like it's not a jumper problem. have you FORMATTED the new drive yet? you kinda need to do that before it will show up in 'my computer'... if you are running windows 2000 or XP pro, go to control panel > administrative tools > computer management > disk management. There you should be able to see the new drive, and format it.
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
