Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-10-2005, 01:16 PM   #1
DonkeyBoy's Avatar
DonkeyBoy is on a distinguished road
Trouble with PCI video card install ... help!!!
Hi, i have been trying to install a seperate video card to my M10000 which has the built in video. I want to improve on the video display when using an Artec usb digital receiver. I currently can pick up loads of channels but the video display is very slow and choppy compared to the sound. I thought it might be due to my mpeg decoder but i would rather have a second video card handling all video etc.
The prob is that i can jot get the card installed correctly. Have looked everywhere now (been over 2 weeks)and had no success. Heres what i am doing.
- Install new card. Boot up with onboard card and install new drivers for pci video card in Xp. Installed and checked ok.
- Power down and disconnect vga lead from on board video and connect to the new video card in the pci slot.
- Have been into my mian bios setting and altered the video adaptor to pci and not onboard
- re boot ......display shows the bios start screen of my graphics card and then i get my main bios load screens. I see windows begin to start and then all i get is a black screen.
- When i power down again and reconnect vga cable to my onboard video. everything woprks ok. It is totally doing me head i now
Does any one have any suggestions or come across any theads that might help.
Regards
VIA EPIA M10000 LVDS 1Ghz Motherboard,
256Ram,80Gig,
Lilliput 7" In Dash Touchscreen
Panasonic Slimline Slot-in Cdrw/dvd Player,
USB Gps Reciever,
Belkin Bluetooth dongle
Belkin USB wifi
Carnetix CNX-P1290 60W Power Regulator
DonkeyBoy is offline   Reply With Quote
Old 08-10-2005, 01:38 PM   #2
evandude's Avatar
evandude is on a distinguished road
alright, well if it gets through the bios stuff with video then it is obviously a windows issue, which is at least a helpful start.
if you boot it with the PCI card, after the screen goes black, have you tried switching the VGA connector back to the on-board video without restarting? if the on-board does have video in that case, then windows must be ignoring the BIOS default video device... Can you entirely disable the on-board video in the BIOS? (rather than just setting the default to PCI)
also, try enabling both displays in windows if dual-display is possible... basically see if you can get any signs of life out of the PCI card when in windows. probably easier if you have 2 monitors to hook up at the same time.
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 08-10-2005, 04:10 PM   #3
Jahntassa's Avatar
Jahntassa is on a distinguished road
Is there a jumper or something on the MB itself to disable the onboard video? Or, as said, something in the BIOS, like under 'Integrated Peripherals' or something?
Actually. I have to wonder if that's exactly what it's doing. XP probably sees both video cards. Try this:
Boot the PC off the internal video card, and get into windows. Go into your display properties and see if it shows a second screen in the 'system' tab, then click to 'extend monitor onto screen'. Then see if it shows up.
It sounds like it's trying to do dual monitors, but you never turned on the second card in windows.
Jahntassa is offline   Reply With Quote
Old 08-10-2005, 04:21 PM   #4
Heckle0's Avatar
Heckle0 is on a distinguished road
I had a simliar issue....i found a way around. If you set the bios back to the onboard and then reboot.....let it sit for a bit....it is actually booting up and will come on the screen once it reaches windows.
Not sure why but it works.
I dont see anything on mine until windows is finally started.
Another Novice?
Progress so far <-------*-> 88%
Kenwood MPV5025 with Aux
Via MII10000
512MB Ram
LG Slim DVD\CDRW
Xenarc 700TS
M1ATX
Pharos GPS
SYBA USB2.0 4-port Hub
Bufalo 54Mbs Wirelessb/g PCMCIA card
Heckle0 is offline   Reply With Quote
Old 08-10-2005, 05:22 PM   #5
DonkeyBoy's Avatar
Thx for all the sugestions. will try em all and let you know.!
256Ram,80Gig,
USB Gps Reciever,
Belkin USB wifi
Best Video Card with composite Video Gadgetboy LCD/Display 0 06-07-2005 10:59 AM
Improving game play. Upgrading video card - how far can I go? ppgt94 General Hardware Discussion 3 06-03-2005 11:37 PM
PCI Video card not working TX5 General Hardware Discussion 9 10-10-2004 11:56 PM
Good, Cheap PCI Video card BumpNGlow General Hardware Discussion 3 07-15-2003 02:24 AM
PCI card riser card allenruble Classified Archive 1 11-25-2001 08:51 AM
