Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-23-2005, 10:58 AM   #1
sxt173's Avatar
sxt173 is on a distinguished road
Exclamation New USB FM Radio
Has anybody seen this yet? Any ideas or comments? Maybe a good solution for FM capability on our carPC's.
Link to Engadget article
C134 Case
VIA EPIA M10000
FrodoPlayer
iGuidance + GPS
7" touchscreen LCD
2000 Mitsubishi Eclipse GT
- V6 216hp
- KYB-AGX adjustable struts
- Konei Alloy 17" rims + Pirelli P-Zero's
- AEM slotted brakes
- AEM CAI
sxt173 is offline   Reply With Quote
Advertisement Sponsored links
Old 08-23-2005, 11:21 AM   #2
sim
sim's Avatar
sim is on a distinguished road
Does'nt seem to be any provision for an external antenna,without one I can't see how you would get reception in a car.
PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
sim is offline   Reply With Quote
Old 08-23-2005, 11:31 AM   #3
sxt173's Avatar
I would be curious to see how the antenna is set up. Just to see if you could hack together a car antenna connection.
C134 Case
VIA EPIA M10000
FrodoPlayer
iGuidance + GPS
7" touchscreen LCD
- V6 216hp
- AEM CAI
Old 08-23-2005, 12:05 PM   #4
contri's Avatar
contri
antenna
I bought an Avermedia USB FM radio for my setup, http://www.pocket-lint.co.uk/review.php?reviewId=502.
A friend and I found out that it got the ground signal, needed for Left and Right sound channels from the USB, and used the then free pin in the headphones as antenna. So, the headphone cable had another cable, quite long, which worked as anttena. Maybe this one does the same trick.
We didn't try it in a car, though. Software control with Fairy Radio wasn't as good as with the mythical D-link one.
contri is offline   Reply With Quote
Old 08-23-2005, 03:55 PM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The DLink isn't mythical. It's no longer manufactured.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-23-2005, 06:13 PM   #6
yargon is on a distinguished road
AFAIK Avermedia USB FM radio uses the ground pin of the headphones jack as ground signal from the antenna, and the left (don't remember now, maybe right) channel pin to real antenna signal.
I'm thinking about soldering a car antenna adaptor to those pins and connect to it to the factory antenna of the car.
As I can see in specs of the car, the impedance of my antenna is 75 Ohms. Can anybody tell me if i'm going to burn my car if I do this?
yargon is offline   Reply With Quote
Old 08-24-2005, 03:36 AM   #7
contri's Avatar
contri
Sorry for the 'mythical', DarquePervert. It seems that 'mighty' was more accurate.
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
USB FM modulator. ppgt94 General Hardware Discussion 4 10-01-2004 03:24 AM
FM CF card Twopoint Car Audio 9 07-18-2004 04:44 AM
FM radio Question thepogcbr900rr General Hardware Discussion 5 05-09-2004 07:27 PM
What are you guys using for FM radio in your carputers ? Nokia6600 General Hardware Discussion 2 03-03-2004 12:35 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
