Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-29-2000, 10:12 PM   #1
Registered User
Post buying an older car....Power questions
Hello,
I am thinking about buying a 1963 ford falcon. I was going to put a mp3 player in my 1997 ford f150 but I am selling it. I was going to power the mp3 playerwith a invertor. Now I am thinking about takign out the console in this '63 falcon and placing my mp3 player there. How could I power it if the car has no cigarette lighter...do I direct hookup to the battery via the fuse box? Can an after market cigarette light be added? Please let me know what you think! Thanks, Shaxs
Car
1964 Ford Falcon powered by a 1993 Mustang 5.0 EFI, AOD transmission, with disc brakes up front and more mechanical goodies
The Player
Gone! Soon goign to repalce the screen based system i HAD with an iPod. http://mp3falcon.crazyshaxs.com
crazyshaxs is offline   Reply With Quote
Advertisement Sponsored links
Old 02-29-2000, 10:38 PM   #2
Post
Most inverters will come with a kit to hook directly up to the battery. So, you can probably do it through the fuse box with little problem.
LoreleiGuy is offline   Reply With Quote
Old 02-29-2000, 10:59 PM   #3
Gutter's Avatar
Post
Don't some older cars run on 6vDC instead of 12vDC?
Anyway, hooking it directly to the battery isn't very hard. That's what I did with mine. You just have to put a switch in, otherwise the player will run when the car is off. I wrote out detailed info about how I did it on my site.
Gutter
http://impee3.hypermart.net
The Impee3 Car Player
Don't Click
Gutter is offline   Reply With Quote
Old 03-01-2000, 10:45 AM   #4
Post
Connect the inverter directly to the battery. This method will insure good power delivery and the Battery will act as a filter somewhat.There should be plenty of holes through the firewall in the Falcon. Is it Generator or Alternator? Either way it would be 12 volt for 63. For a medium to low sized inverter use a 10 or 12 gauge wire. Ground as close as possible to the inverter. Make sure to fuse the inverter at the battery to protect the car. Make sure the inverter is fused at the inverter to protect the electronics. Check out a car stereo shop or Best Buy, Circuit City for a small amp kit and use that. As for a switch to turn it on and off I would personally use a relay. If it has a switch in the inverter that is the best. Remove the switch and extend the wires a bit. Make sure to protect them from the metal case. Get a standard automotive spdt relay (also available a car stereo shop) and wire 85 to ground, 86 to the ignition or accessory in the car, 87 to one wire from the original switch on the inverter and 30 to the other. Now the Inverter will turn on and off with the car. You can also do this if the inverter has no switch but it will be a little different. Wire 85 to ground, 86 to ignition or accessory, 87 to the wire from the battery, and 30 to the power wire of the inverter. Good luck wish I still had my 65 Falcon Ranchero. Jason
jasmar is offline   Reply With Quote
Old 03-02-2000, 01:22 AM   #5
Registered User
Post
Okay, Sounds like adding an invertor is the way I want to go because I would like to have the ability to add a vcr ect. since the lcd takes regular video in. A little bout the car. Its a black 1963 Ford Falcon Futura (I Guess this was a special model, not too many made. I am not to fimiliar with the car model ect, I just drove by it and fell in love ) it has a straight 6 in it and runs good. It has a 3 spd column shift. The body is in nice condition and has new paint on it. Almost all orignal. The only thing that needs to be done (well sorta) is the upholstery. And here is the best part....only 1500 buxs...hehehe. Yeah. Anyways, thanks for the help guys!
-Jason
[This message has been edited by crazyshaxs (edited 03-02-2000).]
Car
The Player
Old 03-02-2000, 04:11 PM   #6
Post
One thing you might want to consider is using a DC/DC PSU instead of an inverter. With older cars especially, an inverter will receive too little voltage while starting (cranking the engine over) and the PC will reboot or hang if it is left on. I have a 1970 Camaro and switched to DC/DC for this very reason.
--Jason
Web site: http://www.m2pc.com
Yahoo Pager: m2pc123
Jason Johnson
Yorba Linda, California
http://www.m2pc.com
M²PC Phase IV - *** PENDING ***
jjohnson is offline   Reply With Quote
Old 03-04-2000, 03:07 AM   #7
Registered User
Post
So, could i just leave the player on all the time and restart the car if I need to ect and just manual turn it off if i get the dc dc power like jjohnson?
Car
The Player
xbox in car questions... new to the forums also, so dont flame me to hard :) tunz98 General Hardware Discussion 16 03-27-2008 02:30 PM
car pc in a 3000gt, have a few questions fastfalcon94 Newbie 15 12-13-2004 07:30 AM
New Morex Car Power Regulator Kit bambooracer Power Supplies 8 06-04-2004 06:15 PM
Power setup questions? Will it work? Know a better way? tom2112 Power Supplies 5 04-22-2004 07:18 AM
About power Supply to PC in car Sk8te General Hardware Discussion 2 11-11-2000 11:39 AM
