Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-27-2005, 03:48 PM   #1
Cheekz185 will become famous soon enough
Hard Drive Question
I want to format my carPC's hard drive. But I dont what to format the harddrive when it is connected to my CarPC. I want to hook the drive up to my desktop computer and format and re-install windows via my desktop cuz it is so much easier. Is it ok to do this? Will it cause any problems?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 09-27-2005, 05:10 PM   #2
tom61
If you're intending to install Windows XP or 2000, you need to run SysPrep before transfering the drive over. I would link you to a guide on doing this, but my internet is funky right now.
tom61 is offline   Reply With Quote
Old 09-27-2005, 05:34 PM   #3
I am using the same HDD just putting the install on the same HDD just on a different computer, then putting the HDD on the car computer
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 09-27-2005, 05:49 PM   #4
tom61
You need sysprep, unless both systems have the same motherboard.
Windows does not like being moved to completely different system. Sysprep is one way around the problem.
The guide I mentioned earlier:
http://www.hardforum.com/showthread.php?t=772307
Oh, if you mean any hardware issues, there shouldn't be any. The only thing to take note of is that it's recommended to format the drive orientated the same way as you'll be running it. I.E. if you're running the harddrive vertically to reduce the risk of a head crash, you should to format it with the drive vertical.
Old 09-27-2005, 06:15 PM   #5
ok so what would happen if i didnt run sysprep?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 09-27-2005, 07:23 PM   #6
84RegalRider's Avatar
84RegalRider is on a distinguished road
You would have to "repair" windows which is just reinstalling.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
84RegalRider is offline   Reply With Quote
Help!!! laptop hard drive ashbosh General Hardware Discussion 9 07-15-2005 02:34 PM
Dvd and hard drive on same cable question zetecdan General Hardware Discussion 3 07-07-2005 01:16 AM
Hard Drive not the usual saintx General Hardware Discussion 15 11-06-2004 05:00 PM
Hard Drive Mounting / SAVE the drive! DerekR General Hardware Discussion 20 03-11-2004 09:07 PM
Idea to protect the hard drive... Szech General Hardware Discussion 9 01-29-2001 10:55 AM
