Okay, some of ya'll may remember that I was having trouble trying to power up my new Epox EP-8RDA+ motherboard. Well, the front Power On/Off Buttons had different connectors because of the Dell OEM case I was going to use. So, I bought this case,
http://www.newegg.com/Product/Produc...82E16811129155 ...
Now, I installed everything and reinstalled time and time again. I can't get the motherboard to power up. I know the motherboard takes the 20-pin connector so I seperate the 24-pin to 20-pin so do I not worry about the other 4-pin connector now? I have a few other connectors left but this case has a power supply with Dual 12V so I believe that I am using all that I need.
Also, the Power On/Off Buttons on the front of the case match up, finally, with the motherboard. However, the PC still doesn't come on. Which way am I suppose to have the Reset connector, HDD LED connector, Power SW connector, etc? I mean does the words go on top or on the bottom?
Please, I really need help. I hope that my motherboard isn't screwed up.... I guess that could be a possibility. I do hear the power supply making a little noise once I disconnect the power plug from it...
