Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-26-2000, 05:17 PM   #1
BluCivic93
Question remote turn on lead from headunit to power up PC
I have a DCDC PSU and I already have power distribution in the trunk of my car, so I don't want to run another line and put a switch on it up front. I would like to have the DCDC power up when I start the car and power down when I turn it off. So the remote turn on lead that turns on my amps would appear to be the obvious easy choice. Is there anyway to do this?? I have the Arise 865V DCDC supply. Thanks a lot!
Blu
BluCivic93 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-26-2000, 05:31 PM   #2
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
Post
Just use a big fat relay to switch the battery voltage going into the PSU. If your remote turn on lead doesn't have enough power to drive the relay, use an emitter follower or open collector transistor to give it more juice.
Rob
-- <A HREF="http://www.nav.to/robwithey" TARGET=_blank>http://www.nav.to/robwithey
</A>
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 07-27-2000, 01:47 PM   #3
BluCivic93
Post
Would Radio Shack have such a relay or will I have to go somewhere else? Do you know of any such place where I can get the relay? If the remote turn on lead wouldn't work, could the accessory wire from the car work better? Thanks.
Blu
Old 07-27-2000, 03:13 PM   #4
byaroch
Post
Radio Shack has a 12V 30amp realy. They label it as an automotive relay. (it's black) That should work perfectly.
byaroch is offline   Reply With Quote
