The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 11-08-2005, 12:21 PM   #1
My Photos: (0)
SERIOUS Vibration Insulation
Hi Gents,
I need advice on how to insulate as best as possible, an In-Car PC and Hard Disk from extreme vibration...
The PC will be installed in what would be the boot are of a large hatchback, with the rear seats removed, and replaced with a large subwoofer enclosure going right up to the B pillars...
The PC will sit behind this "speaker wall" at the back of the car...
So, how can I insulate the case and sensitive components from vibration? My thoughts so far...
- Use a bootable Flash Media drive for O/S and programs
- Use a 2.5" Laptop harddrive for storing movies/music etc
- Make an birch-ply case for the motherboard and components
- Sit this inside another, larger case, which will be lined with closed cell foam to give a snug fit
Any other suggestions? I'm worried about scapping hard drives regularly or the OS crashing due to the loud speaker system in the car...
Cheers
Rich
BladeUK is offline   Reply With Quote
Sponsored Links
Old 11-08-2005, 10:06 PM   #2
phc
phc's Avatar
Vehicle: 2004 WRX Wagon
My Photos: (0)
Use what the military uses to isolate avionics from shock and vibration, Barry Mounts.
Link: http://www.surplussales.com/Cab-Rack...hockmount.html
(RPS) L22-BA-0.7
I've used them in BattleBots for 3 years, work great and fairly cheap. They do take up room and you will need to get 4 of them.
www.mechatroniks.com - Bots
www.mechatroniks.com/wrx - Car PC Project
-=Now offering a Lilliput Bezel for WRX=-
**Sept 2005 - website moved to mechatroniks.com**
phc is offline   Reply With Quote
Old 11-09-2005, 12:06 AM   #3
My Photos: (0)
That particular model says it supports 0.4-0.77 lbs each. So for 4, that's only a max of about 3.1lbs, right? Most computers weigh more than that... or am I misunderstanding what that weight rating represents?
WxGuy1 is offline   Reply With Quote
Old 11-09-2005, 05:36 AM   #4
My Photos: (0)
theres multiple ones on that site. 20-30 lbs. 50+ etc.
i made a case out of a old hp removable motherboard tray, glued it to a fiberglass mold and that was that. lol. my pci slots need to be secured somehow though. i gotta figure out how its going to work. i glued the harddrive to teh fiberglass. as well as the power supply.
its been running like this since january with very minute problems. mostly because of the hard drive i used was a old crappy laptop drive. i have an exernal 3.5" HD pushing 160gb with 26000 mp3's no problem. the 3.5" is mounted flat to my floor. i had it standing up before but the place i mounted it now wont allow it to be mounted upright anymore.
btw.. i have 2kW RMS feeding my stereo. so its not exactly like im running little bitty stereo system.
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
miztahsparklez is offline   Reply With Quote
Old 11-09-2005, 06:13 AM   #5
My Photos: (0)
Speaker vibration is nothing to hard drives and such.
ElKeeed is offline   Reply With Quote
Old 11-09-2005, 11:47 AM   #6
My Photos: (0)
Very helpful stuff Gents, nice one...
It'll be a large system doing 155dB+ @ 40-50hz, 4 15" subs with around 12Kw RMS power meaning that a lot of protection is needed!
I'm looking to run/boot the OS off flashmedia... Any reccomendations on the viability of this?
I'd like to keep the 2.5" hard drive in a 2.5" -> 3.5" dampening case, then pop this 3.5" block into an external USB case for quick removal from the car...
This does mean that another power supply would be needed to the case, is there a way around this at all?
Cheers
Rich
Old 11-09-2005, 02:02 PM   #7
My Photos: (0)
the external drive will need a power supply. why a laptop drive though?
i believe what i have now can push 140+ db in my custom tuned vented enclosure. with 12kw rms id be more woried about supplying your computer with enough power without huge voltage drops. voltage drops will cause the computer to crash more so than the vibrations would.
Old 11-12-2005, 01:47 PM   #8
My Photos: (0)
I was planning on using a Laptop drive as they are more tollerant of vibrations?
Can external 2.5" drives not be powered by USB? This would make things a lot easier!
Power supply isn't a problem, there will be an additional bank of batteries in the boot to keep voltage up...
Cheers
Rich
Old 11-12-2005, 06:45 PM   #9
My Photos: (0)
not exactly.. they both are quite similar when they are moving. but laptops may have higher tolerances when they are off. in either case, save yourself some money and get a bigger and faster drive. i use a seagate 7200rpm drive.
try putting a capacitor in line with the computer power supply. that way it will keep the voltage going to teh computer at a somewhat constant rate instead of having spikes all over the place.
Old 11-13-2005, 12:39 PM   #10
phc
phc's Avatar
My Photos: (0)
Your weight calculation is correct. Barrymounts are/were made in a wide range of weight ranges, if you look around you will be able to find a wider variety of parts.
If you are in the Burbank area, you can go to Apex electronics, they have boxes of these things. http://www.apexelectronic.com/
Sponsored Links
Old 06-13-2006, 05:29 AM   #11
Tim Lake's CarPC Specs
Tim Lake's Avatar
Vehicle: 1999 Nissan Primera
My Photos: (0)
If you go with your plan of padding the box inside another box you might have some heat dissipation problems.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Tim Lake is offline   Reply With Quote
Old 06-13-2006, 06:25 AM   #12
My man uses Levitra.
Peoples's Avatar
Vehicle: '00 Honda Accord Coupe v6
My Photos: (0)
if you search the form, this has been discussed over, and over, and over, and over, and over again. Basically tons of people on here have had their harddrives go through hell, and have had no problems. I've driven on 10 miles of gravel road with my system right near the sub, no problems. People have been in accidents, their computer still running solid...etc. My hdd does have shock absorbant mounts, but their main purpose if to limin vibration noise between the hdd and the cooling bracket I have on there. The mounts came with my hdd mount.
Pic of the mounts
http://www.azpoint.net/img/articoli/...C2/Gommini.JPG
the hdd cooler itself
http://images.google.com/images?q=za...&start=40&sa=N
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 06-13-2006, 04:39 PM   #13
hunterius's Avatar
Vehicle: 94 Pontiac Firebird
My Photos: (0)
what about this?
http://www.mp3car.com/vbulletin/showthread.php?t=77978
"We cannot solve our problems with the same thinking we used when we created them."
AE
hunterius is offline   Reply With Quote
Old 06-13-2006, 07:00 PM   #14
TheLandYacht's Avatar
Vehicle: 2005/Dodge/Sprinter
My Photos: (0)
Actually, the box-within-a-box idea sounds like a reasonable idea. Define closed-cell foam...are you talkin upholstery cushioning? That sounds like a great idea...gotta keep ventilation in mind though.
TheLandYacht is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hard drive shock / vibration thoughts S11D336B General Hardware Discussion 60 09-26-2006 11:40 PM
serious error NYCdesignkid Power Supplies 2 02-02-2005 09:26 AM
Heat insulation ryuandwings General MP3Car Discussion 3 11-16-2004 07:58 PM
problems from road vibration seven10split General Hardware Discussion 3 08-08-2000 11:47 AM
is meci.com serious? maromba General Hardware Discussion 2 01-18-2000 07:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
