Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 11-09-2005, 05:24 PM   #1
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Wiring backup/Rearview camera -- can engine crank damage?!
I have began planning the installation/wiring of my rear-view (backup) camera, and while at it I have come across a couple of uncertainties
I plan to wire the camera (12V DC) directly to one of my reverse white lamps. This way, when I backup my car in reverse, the camera will be powered, and my Xenarc will autoswitch. OK, nothing new here so far, now the question...
My car is a 5-speed manual. I normally engage my vehicle in reverse after parking and shutoff the engine. What this means, is that when I start my engine later, it is normally already engaged in reverse, so I am cranking my engine with clutch down, and gear in reverse...
Under these conditions, I am initially powering the camera while cranking the engine, because the rear lamps are effectively powered while starting the car (gear is in reverse). I assume the voltage will be somewhat below 12V while cranking (need to measure it still) -- can this damage the camera? Also, could the voltage actually go above 12V while or after cranking the engine, and would it damage the camera?
I'm thinking about putting an inline fuse for this, but not sure to what extent this would protect me... surely won't protect me against under-voltage
Thanks for feedback/suggestions.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 11-10-2005, 11:04 PM   #2
Raw Wave
justintime's Avatar
Bump. Anyone? Stupid question? has it been answered before? Could not find anything.
Thx
2002 Honda CR-V
Old 11-10-2005, 11:12 PM   #3
roadhog's Avatar
roadhog is on a distinguished road
I think the biggest potential problem with electronic devices during cranking is that the alternator can produce some nasty spikes. I have had a mobile phone charger fail at this point in proceedings so I think it is possible. Some kind of power smoother would therefore better than fuse, something like an inline choke and capacitor across the supply could do the trick.
roadhog is offline   Reply With Quote
Old 11-10-2005, 11:14 PM   #4
kamikaze2112's Avatar
kamikaze2112 is on a distinguished road
well, i know that when i crank my car, none of my accessories are on. I think your camera is going to come on for a second, then off while the car is cranking, an then back on again after the engine is running. You might be able to wire in some sort of delay to keep it off til your engine is started, however, it will delay the monitor autoswitching as well.
kamikaze2112 is offline   Reply With Quote
Old 11-10-2005, 11:16 PM   #5
Raw Wave
justintime's Avatar
SO if I'm reading this right, anything above 12V could potentially damage the camera, but anything below 12V is OK?
Thing is, the camera instructions say that both above and below are problematic. but it doesn't explain any further. Of course.
2002 Honda CR-V
Old 11-10-2005, 11:17 PM   #6
roadhog's Avatar
Not sure re the acc cutout, maybe have someone check if the reverse lights cut out during cranking?
Old 11-10-2005, 11:20 PM   #7
roadhog's Avatar
I can't give you any figures, but I believe the power spikes can be significantly above 12v. The thing is, they have such a short duration (micro seconds) that things like bulbs and so on aren't really affected.
Old 11-10-2005, 11:20 PM   #8
Raw Wave
justintime's Avatar
Tried that first! My wife did not notice any interruption in the lights while cranking etc...
2002 Honda CR-V
Old 11-10-2005, 11:24 PM   #9
roadhog's Avatar
Sorry... I often state the obvious
Old 11-11-2005, 12:05 AM   #10
sYx66 is on a distinguished road
I don't see reason why you must put your manual transmission into reverse. Simply re-learn to put it in first gear. The ratios are very close.
Your eq might suffer only if there is over 12V spike. It won't suffer if there is less voltage. Certanly you can get one of the DC-DC power supplies and put that between. They have capacitors that try to keep voltage steady during a crank. I don't it's worth the money though just for a camera?
sYx66 is offline   Reply With Quote
Old 11-11-2005, 12:37 AM   #11
roadhog's Avatar
or could you take a +12 volt feed from the computer PSU?
Old 11-11-2005, 07:51 AM   #12
Raw Wave
justintime's Avatar
Taking the feed from the PSU is not really an option, because I want it to power up the camera ONLY when in reverse....
2002 Honda CR-V
Old 11-11-2005, 01:03 PM   #13
BoraXP's Avatar
BoraXP
put it on a relay powered by the PSU and triggered by the reverse light
BoraXP is offline   Reply With Quote
Old 11-11-2005, 01:14 PM   #14
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Why the **** do you put it in reverse when parked???????
Enforcer is offline   Reply With Quote
Old 11-11-2005, 01:20 PM   #15
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Yeah, why reverse when parked? Either do first gear, or remove from reverse prior to cranking....
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
[REVIEW] In-Bumper Rear-view camera RoyN General Hardware Discussion 104 12-30-2006 03:42 PM
Using a high farad cap to survive engine crank lakorai Power Supplies 6 03-28-2005 10:47 AM
why is my backup camera not working with my capture card? nappyjim General Hardware Discussion 0 02-17-2005 03:52 PM
Carputering when car engine is off + survive crank mashina Newbie 3 08-14-2004 01:31 PM
Opus and diesel engine crank? bridqer Power Supplies 5 03-08-2004 09:59 PM
