Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-10-2005, 10:54 PM   #1
Power switch question
...maybe a simple question, but I want to run a switch from my mobo and mount it on my dash somewhere that would turn the power on/off to my pc. What kind of switch do I need. I was using the hacked power button from an old tower. I thought I needed a momentary switch but that didn't work so well.
The switch would run to the pins on my mobo if that helps.
gambit32 is offline   Reply With Quote
Old 12-10-2005, 10:59 PM   #2
binary.h4x's Avatar
A normally open momentary switch.
binary.h4x is offline   Reply With Quote
Old 12-11-2005, 10:36 AM   #3
Raw Wave
TruckinMP3's Avatar
If the cable run is long, you might get better results from a relay and switch.
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 12-12-2005, 04:34 PM   #4
It's actually called a 'normally' open momentary switch?
Old 12-12-2005, 07:24 PM   #5
binary.h4x's Avatar
yup
PS2 used as case and working PS2 reset/eject switch as power and reset Silentbob343 Hardware Development 3 09-07-2005 10:09 AM
Opus 90w power switch wire connection question Tim97rs Power Supplies 0 05-13-2005 07:37 PM
Switch letting power through veetid Power Supplies 10 06-08-2004 01:09 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
question for aaron, or anyone, about power switches daver Power Supplies 11 10-28-2001 01:02 AM
