01-15-2006, 06:01 PM
#1
AMD Geode NX 1750
Hey, i saw a great deal for the AMD Geode NX 1750, which runs at 14 watts and is 1.4GHz with a biostar mobo for 85
http://www.directron.com/m7vig4comb29.html.
I havent heard much about the Geode CPU's. Does any one have any experiance with the Geode, since few-non is posted about them. They seem perfect for a car PC: little heat (can operate fanless) and little power.
I guess my biggest question is if the 1.4GHz is enough to run a car PC with DVD, XP, GPS, ....
02-28-2007, 08:51 PM
#2
Newegg has a Jetway board now...or did...
I guess I bought their last one...
<SOLD>
ATi RS485 AMD S939 Venice 2GHz (Yes, I had a A64 in my car!)
CURRENT
Jetway J7F3E-PB Geode NX1750, 512M, 120G 2.5" SATA HDD, Sony slim combo drive, Lilliput 7"touchscreen, 60G external WD, GPS, WiFi, mini-keyboard
02-28-2007, 09:19 PM
#3
I saw you had your other setups for sale, so what board did you get and what case are you putting it in?
03-04-2007, 09:02 PM
#4
Jetway's J7F3E-PB from Newegg. I'm putting it in a
http://www.newegg.com/Product/Produc...82E16811165041
NEEEET little case...
It was "SOLD OUT" , then they had it, I ordered, and NOW, the price has jumped up $10...WHEW....just in time
NOW...to find a decent 2.5" SATA drive...
<SOLD>
CURRENT
03-04-2007, 09:32 PM
#5
Location: Singapore - Smallest country in Southeast Asia
is the CPU included for newegg's J7F3-PB?
03-04-2007, 09:47 PM
#6
YEP...
The heatsink was hanging on one clip, so make sure that it's installed correctly before starting it up.
I'd like to take this opportunity to also say that the core of the cpu was covered with about ten times as much thermal interface material than what was needed. It covered almost the entire cpu. What a mess!
I cleaned it all up and put on some good stuff...
I'll probably end up putting on another heatsink anyway. This fan is a little louder than I like. I think it's a 50mm fan and it spins at ~5K rpm...it whines a little like a harddrive...I'll know more once I get it in a case...
<SOLD>
CURRENT
03-05-2007, 10:41 AM
#7
how does it compare to the boards with the c7 1.5ghz cpu? and the graphics, is there a better performance than the other boards (jetway j2f2 boards)
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
03-05-2007, 11:34 AM
#8
One thing is, unless it says otherwise in the item description or something, it's probably safe to assume that the mobo won't support standby. I've bought a couple of boards as "combos" with uncommon processors (such as the geode) and they didn't support standby. http://www.mp3car.com/vbulletin/show...ighlight=geode
Haven't had that particular board, though, but it's just something to look out for, if you care about standby.
The PC CHIPS motherboard combo that I bought that came with a geode processor turned out to be a complete waste anyway. Just because the processor is low-power doesn't mean the mobo will be. Comparing between that board and a similar board with an athlon XP-M, the power consumption wasn't even that much lower, and the overall consumption was still several times higher than that of the CPU itself - I don't remember the specifics, but I think it was around 55-60W. It's not that surprising, because real low-power boards like the EPIA series are designed from the ground up to be efficient, whereas these combo boards are nothing but regular mobos with some minor tweaks so they work with the geode (or other) processors which didn't exist when they were originally designed - and these mobos weren't exactly high-end in the first place.
Anyway, just some things to think about.
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
03-05-2007, 11:40 AM
#9
i have it, i got a combo deal from geeks.com about 3 months ago, works great, i ran it from la to lasvegas for the all star game and with music, gps, and a movie and it never messed up, and from hibernation to it being ready takes like 7-10 seconds, and i have a full install windows xp, with nothing optimized for speed or anything
03-06-2007, 08:12 PM
#10
Newegg has the J7F3E-PB again...and it's cheaper now than when I bought it just a week ago...
Get 'em while you can!!
http://www.newegg.com/Product/Produc...82E16813153052
<SOLD>
CURRENT
03-09-2007, 10:24 PM
#11
I've got the MOBO, and the Carputer is lighting fast (for the purposes). The fan is LOUD (but who cares, it's in the trunk). It will NOT Standby, not even Hybernate (may have to play with it some more). But it does boot up unmodified WinXP in under 30 seconds with a 7200 RPM hdd, so it's ok. I'm using my carputer though the AUX input on my stock radio, so I can afford a few extra seconds of bootup.
I do recommend this as a great value. I have a Via CPU as my home file server and it's SLOW. I would LOVE to have one of those $300+ Core motherboards, but come on, it's like $500+ once you add the CPU, so this is the best compromise for price vs perfomance.
As far as power, it works great with the 120 watt Opus, and I do have a PCI Wifi card connected to it plus the HDD, 3 USB devices. I even connected a 8 year old CD drive to it to load windows and it still worked. CarPC application is not exactly "low power", it's more like "not too much power"
| Thread Tools |
| Display Modes |
Linear Mode
